08-15-2014, 10:31 AM
Premier 2514G Electrical Question
I have a 2015, Premier 2514G. Under the bench seat, near the front of the trailer is where the Electrical Panel is. In this area, under the seat and not really accessible is a wired GFI outlet. Any idea why it's there? The wire running to it is yellow, and all the other electrical outlets are wired with white wire. Nothing mentioned in any of the manuals.
08-15-2014, 11:10 AM
Picture's always help us understand!
TURBS
"SABRE OWNERS UNITED"
08-15-2014, 12:01 PM
08-15-2014, 12:05 PM
Do you have air conditioning? If not I bet that is what it is for.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
That's possibly for a remote mounted converter.
Depending on what converter is spec 'd for the trailer it may be hardwired or plugged in.
I can't quite tell but is that a twenty amp outlet?
TURBS
08-15-2014, 12:07 PM
Also is your water heater gas only and in that same compartment?
TURBS
08-15-2014, 12:08 PM
Water heater is gas or electric. No A/C on trailer.
08-16-2014, 08:21 AM
Sure looks like a plug for a fridge. Wonder if the tech just installed it thinking your pup was a different model or something. Could just be a mistake.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
08-16-2014, 08:43 AM
Might just be to provide protection to the rest of a circuit downstream. Do any other the other plugs quit if you trip the GFI?
I've got a weird GFI like that in my house that's tucked away in a useless location, but it's for the power that runs to the shed. If I loose power in the shed I have to go down to my basement and get into the storage space under my stairs (moving all the Christmas decorations) to reset it.
08-16-2014, 10:39 AM
This GFI has no buttons (like the rest in the trailer) just the one box on the wall by the rear side bed has buttons that shut down all the sockets in the whole trailer.
08-16-2014, 11:09 AM
Oh, so then it's not a GFI, it's just a regular outlet.
08-16-2014, 11:17 AM
The outlet is probably for an option you do not have. If you check an options list you may be able to figure what would go there. The color of the Romex denotes the amperage,
White - #14 = 15 amp
Yellow - #12 = 20 amps
Orange - #10 = 30 amps
And it is correct that it is not a GFCI Outlet, it is a decora outlet
Started Out With Nothing,
Still Have Most Of It Left!
08-25-2014, 07:28 PM
We have the same thing on ours. It's for the roof mounted air conditioning. That is also what the extra black access door on the drivers side is for, to run the cord up to the AC unit. We plugged a power strip onto it and use it for charging the flashlights.
08-25-2014, 07:30 PM
Another mystery solved.
