Old 04-06-2015, 01:11 PM   #1
Problem with motorized winch
I have a Clipper 108st with a motorized winch. Camper has been stored in the garage for the past three months after camping with it. Tries to use the motorized winch to lift the top and no movement. All latches are unlached and I even lifted each side and corner to make sure nothing was stuck. Battery is good. Any suggestions? I am going to try to bypass the 50 amp fuse from the battery next.
Roger is offline   Reply With Quote
Old 04-06-2015, 06:23 PM   #2
lickitisplit's Avatar
I would recommend the process of elimination. First, check the battery connections are tight and clean. Check/replace the fuse. If you have a multi-meter, check current at the battery and fuse. Finally, I would try to manually crank it a little to see if it might be seized up. Sometimes you get road debris caught up in the cables or crank. I would chase the cables and make sure they are good and not binding up.
2015 Rockwood Freedom 2280
2011 Chevrolet Silverado
1979 Wife (Shannan)
2007 Boston Terrier (Darla)
2012 French Bulldog (Rocko)
lickitisplit is offline   Reply With Quote
Old 04-08-2015, 08:46 PM   #3
f5moab's Avatar
Here's some further info...
Wicked Winch - Lift System Troubleshooting for Flagstaff Camping Trailers | Roberts Sales
f5moab is offline   Reply With Quote
