Old 06-06-2012, 10:43 AM   #11
There is a little switch .. either on peripheral of the roof .. or something that you fold up ..like the sink/stove unit that has stuck to the closed position -making the system think the interiors should be off as not to start a fire. Find the switch .. its like a pushbutton thingy .. give it a couple of pushes .. and dollars to donuts you will have light ...
trust me .. its in no way a converter issue ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 06-06-2012, 12:01 PM   #12
I found the problem. Oh, and D-mo, you were correct....
The yellow wire on the bottom had been pulled off and disappeared down the hole. I didnt know it was there so I didnt realize something was missing. I finally found it by pulling out a drawer and looking behind it and seeing the wire hanging down. I fed it back thru the hole and plugged it back in and it all worked. It looks like a little kill switch that turns off the lights when the bed is pushed in.
I suppose the good part of this is I now have a much better understanding of how the electrical system works in my pop-up... lol
Thanks for all the help everyone.
fisk
fisk is offline   Reply With Quote
Old 06-06-2012, 12:16 PM   #13
All is good ... glad you found the problem .. usually stuff like this is related to simple stuff .. not the catastrophic failures ... thanks for following up.
d-mo
2011 Rockwood A122
