Old 07-10-2016, 10:24 AM   #11
Campster's Avatar
Originally Posted by Mr. Dan View Post
OP said he had a 3-way (not a 2-way). One of the 3 ways is 12v.
Missed that! Thanks for pointing that out, I also wasn't aware there was a 3 way, only had 2 choices in every unit I have owned. It's Sunday and school is in, learned something new today...
Campster is offline   Reply With Quote
Old 07-10-2016, 11:24 AM   #12
raspivey's Avatar
I'm thinking that's probably because of the size and the power consumption required to run the heating element to do more than maintain a smaller refrigerator. My popup had...I think a 1.9 cf. I ran 12V when driving and it always stayed cold. The longest trip was about 6 hrs. I do a few 2.5 hr trips boondocking a year and paid more attention to battery charge on those trips. I never noticed a real drop in voltage after the drive, but that may have been due to the refrigerator already being cold when I left and the increased air flow while driving (they don't vent very well and hot days make it work harder) so it may not have turned on but briefly during those trips. Just don't leave it on 12V if stopped for more than 1/2 hr or so. Run propane the rest of the time. I could go 9 months (probably 20 - 30 days use) on a bottle with occasional cooking and furnace use. Refrigerator uses very little.
2012 Chevy Tahoe LTZ - HD tow package
Old 07-11-2016, 09:20 AM   #13
You might be surprised at how an RV fridge uses 12V power. As already mentioned, it's used for the control board and spark igniter but also provides power to other things.
If you have a spark igniter, you also have a gas valve that draws 12V power when the burner is lit. Your fridge may also have a door heating element to keep condensation from forming on the door seal. An interior light draws power when the door is open but its power consumption can be ignored because the door is open so little of the time.
If you're boondocking, it's always a wise thing to examine all of your appliances to determine exactly how much battery power they consume and what functions, if any, you can disable to conserve power.
My (larger) Dometic fridge draws around 300W for the AC electric heating element, around 2.5A at 110V. When I run the fridge using the inverter, it draws around 26A at 12V which limits that usage to times when an alternator can provide the 12V power or for an hour or so shopping excursion. The door heating element draws 1A all the time; 24A/day, a significant drain when boondocking so I unplug the heater/light at the control board when I'll be running on batteries for an extended period of time. My class A Georgetown also has a safety shutoff solenoid at the propane tank which draws power whenever the rig's propane is turned on. The original solenoid drew over 1A while the replacement that was installed after the first one melted its coil draws a bit less than that.
Phil
pmsherman is offline   Reply With Quote
Old 07-11-2016, 11:01 AM   #14
raspivey's Avatar
Three way refrigerators generally have none of those things.
Old 07-11-2016, 11:16 AM   #15
Doubt very much if the battery could last 12 hours running the frig. Propane, no problem.
Old 07-11-2016, 04:53 PM   #16
A popup three way fridge does not use any 12v when it is running on propane. My first popup did not even have a battery.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 07-11-2016, 06:27 PM   #17
Mr. Dan's Avatar
Campster, I know enough about them to point out they are not like 2-way refrigerators BUT not enough to give ANY suggestions about their operation.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 00; booked = 14
Old 07-11-2016, 06:43 PM   #18
Hugeez's Avatar
Originally Posted by Happy Vibe View Post
Low med and high refer to the size of flame. So low would give you the least cooling. It all depends on the ambient temperature. If it is hot you will need to run it on med or high. You will need to experiment to see what setting works best for you. At the hotel at night and no one opening the fridge you should be able to leave it on low.
This is my first TT. I did not even know there was an adjustment for the size of the flame. Have not looked but guessing it is behind one of the doors on the outside of the TT on the back side of the fridge?
2015 Puma 29RBKS
2013 Ram 1500 5.7 Hemi 4X4
E2 WDH 10000lbs Air Lift Rear Helper Springs
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
Hugeez is offline   Reply With Quote
Old 07-11-2016, 07:41 PM   #19
Propane consumption for refrig?
This only applies to 3 way (small) fridges used in popup's. In all the TT fridges I have seen you can't adjust the flame.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
propane
