Old 07-10-2016, 07:31 AM   #1
Propane consumption for refrig?
Hello fellow campers. Our 2013 Mac 246D pup has a 3 way refrigerator. My question is we're going to spend a night in a hotel with a stocked frig. and was wondering which would be the best thing run it on propane or 12v. The battery is factory and fully charged but I don't won't to run it dead. Also my propane tank is full(20#). I don't won't it empty either. Does anyone no the approx. consumption of the 2. It will be unattended for about 12hours. Also on the propane knob it has low, med. and high. Does low mean colder frig?
Thanks!
Sent from my iPhone using Forest River Forumsdaverobenolt
daverobenolt is offline   Reply With Quote
Old 07-10-2016, 07:38 AM   #2
Georgia Frog Rally 2017
aceinspp's Avatar
Just run off propane refrig does not use that much. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2015--46
Days booked for 2016--60 missed by 2
Days camped in 2016 58
aceinspp is online now   Reply With Quote
Old 07-10-2016, 07:40 AM   #3
Run the unit on Propane, switch to Elec. when at C/G! Your batt should last 12 Hr the propane should last for most Trips "UNLESS" you run the Furnace! Youroo!!
Old 07-10-2016, 08:00 AM   #4
That's what I was thinking. I ran it on propane and noticed that the flame is not much more than a pilot light type flame. Does low mean colder frig?
Thanks much!!
Old 07-10-2016, 08:25 AM   #5
Refrig will last at least twenty days on 20 lbs propane.
wanderingbob is offline   Reply With Quote
Old 07-10-2016, 08:32 AM   #6
Low med and high refer to the size of flame. So low would give you the least cooling. It all depends on the ambient temperature. If it is hot you will need to run it on med or high. You will need to experiment to see what setting works best for you. At the hotel at night and no one opening the fridge you should be able to leave it on low.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 07-10-2016, 09:12 AM   #7
Oaklevel's Avatar
A frig uses very little propane...........
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 07-10-2016, 09:56 AM   #8
Campster's Avatar
Thanks!
I wasn't aware frig's ran on 12v alone? I thought the only thing 12v was used for was the sparker for the propane flame. Mine either uses A.C. which still is converted to 12v for the sparker or propane and 12v from the battery for the sparker. The frig will not run with the battery only and the propane tanks turned off.
Campster is offline   Reply With Quote
Old 07-10-2016, 09:58 AM   #9
TURBS's Avatar
He has a three way fridge, pretty much only used in pop ups and some tent campers
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-10-2016, 09:59 AM   #10
Mr. Dan's Avatar
OP said he had a 3-way (not a 2-way). One of the 3 ways is 12v.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85
propane
