The sail switch tells the furnace controls to open the gas valve, if it was bad the furnace would not fire. But with your trailer being a 2008 it probably could use some cleaning. The only thing that is common with all furnaces is the burner. Make sure the flue, orifice, and thermocouple are clean. Use a small wire brush to clean the items mentioned. Be careful you don't use too much force and bend something. Not knowing the make and model of the furnace it is hard to tell you how to proceed with cleaning the insides of the furnace where the fan, sail, and sail switch are located.
Do a search for "how to clean Atwood rv furnace" or "how to clean a Suburban rv furnace" and you will find many technical and not so technical links.
Here are the service manuals for both Atwood and Suburban furnaces to help you get started.
Richard & Jill
