12-01-2018, 06:51 AM
Propane usage
In mid 20 degree temps at night, only using furnace at night, how long will a 20 lb cylinder last?
12-01-2018, 06:58 AM
How big is your TT/MH? In a small TT it will last most of a week maybe in a 40' MH not so long.
12-01-2018, 06:59 AM
It all depends on which RV you have, how protected from wind you are and a few other things. So, it's almost impossible for us to say how long your cylinder of LP will last.
Gotta go campin!
12-01-2018, 07:04 AM
Not long.
Bruce
12-01-2018, 07:23 AM
Each pound of propane has as I remember about 90,000 BTU’s..
If your furnace is 40,000 btu it will burn continuously for about 45 hours on a #20 tank.
The less it is on the longer it lasts.
The hot water heater and fridge burn some as well.
12-01-2018, 07:53 AM
The OP has a 2016 Flagstaff M.A.C. Series M-206LTD
Bruce
12-01-2018, 08:19 AM
Uhh, I think that maybe you meant a "gallon" of propane has around 90,000 BTU's and not a pound.
https://www.propanetankstore.com/blo...-propane-last/
https://www.elgas.com.au/blog/1675-p...-therms-ft-usa
2011 Flagstaff 831 RLBSS
12-01-2018, 08:26 AM
Without trying to derail this thread.... we need more information.
1. battery(s) will run down in a day or 2 unless you are plugged into shore power or
run a generator.
2. IF you are plugged into shore power you need an electric heater!!!
3. Read #2 above!!!
4. Everything else.... set furnace thermostat at lowest setting. Get flannel sheets. Get a down comforter or use a down sleeping bag as a comforter.
Good luck!
Peace!
Dan & Rita D
