Old 09-28-2015, 01:29 PM   #1
Pup closed up: fridge door closed or cracked open?
We just bought our first 2015 1940LTD pop-up a little over a year ago. Since then I've kept the fridge door cracked open when it is folded and closed up. This makes it a pain to start it cooling down because I either have to wait until camp or try to contort myself to reach in and close it.
I haven't wanted to risk mold/mildew but am I too cautious? Could it stay closed during the summer when it is collapsed or am I asking for trouble?
Help a newbie out!
Thanks!
cyberalexander
cyberalexander is offline   Reply With Quote
Old 09-28-2015, 01:47 PM   #2
rsdata's Avatar
make sure it is dry by using a towel to dry it out then run a fan into the open fridge and let it fully dry out... then put an opened box (pull off the top) of Arm and Hammer baking soda in the box before you close it after you get home
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 09-28-2015, 01:48 PM   #3
Keep it closed during the camping season and prop it open during winter storage.
latner is offline   Reply With Quote
Old 09-28-2015, 08:02 PM   #4
I kept mine propped open all times. When you break camp there is a lot of moisture in the fins that a towel won't get out. Rather slide in sideways to latch it than risk smell of mold, mildew later. I have also started using Damp Rid in the A frame if it will be closed for a prolonged period. Sponge in cushions will suck up moisture if left to itself.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-28-2015, 08:15 PM   #5
I'm with Dobe. Keep it open when not in use. We did that with our Coleman. Went 20 yrs with no mold issues. Better to be safe than sorry. You'll like replacing the fridge a LOT less than getting in to open/close the door.
2011 Traverse LT, 3.6L, FWD
Old 09-28-2015, 08:27 PM   #6
deartruc's Avatar
I'm the guy who always plugs in between trips...so I kept them closed. Normally, during season, we were camping every other week or two, so it was convenient. Winter, always open. PUP to HTT did the same.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 09-28-2015, 08:41 PM   #7
Flybob's Avatar
Back when we had our PUP, we cranked the top up a few inches to allow for the door to be opened, Then crawled in to close fridge. I left the switch set to AC and just needed to plug in to start fridge.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-29-2015, 06:31 AM   #8
my 2016 has a toggle on the door with 2 positions, locked, and propped open 1/4 inch
when its in the garage its propped open 1/4 inch, I can raise the roof and crawl in and close it so i can pre-chill the fridge
When i do that I unplug the fridge from the outlet on the PUP and run an extension cord, as I have my battery on a maintainer and don't need the converter kicking on putting power to the stereo and such.
swimmarz is offline   Reply With Quote
Old 09-29-2015, 12:08 PM   #9
Originally Posted by swimmarz View Post
my 2016 has a toggle on the door with 2 positions, locked, and propped open 1/4 inch.
Ours has the latch builtin the door latch to prop open. Little while back my son turned fridge off but did not prop open and had some mildew and smell.
Steven & Tiffany
2015 Crusader 296BHS
2013 Chevy 2500HD LTZ CC Z71
Camp as often as we can
Steven379 is offline   Reply With Quote
Old 09-29-2015, 12:19 PM   #10
I have had good luck by drying the fridge with a towel, and then loosely wad up some newspaper inside on each shelf and the freezer. Then close the door.
Never had a problem, because the paper will absorb any remaining moisture.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
door, fridge
