Old 04-10-2013, 06:24 PM   #1
Re-caulk Roof - 2006 Rockwood Freedom 1940 LTD
I recently purchased this Rockwood Freedom 1940 LTD pop up and want to re-caulk the roof prior to use this summer. I have removed the caulking next to the edge caps on the roof that run the length of the pop up on either side front to back. Can I now just re-caulk with some Dicor Self Leveling on the roof next to the edging or is there a need to remove the edging, caulk underneath it and then replace and caulk next to it?
Hope my question makes sense. Thanks in advance for the feedback.
bkkrehbiel is offline   Reply With Quote
Old 04-11-2013, 02:03 PM   #2
daydreaming about camping
jeeplj8's Avatar
If you took it to a dealer to do, they would simply apply the dicor self leveling lap sealant at this point.
I went around with some de-greaser before I did mine just to remove any residue.
So long as the dicor sealant is completely covering any gap between the roof material and the edge cap, you are good to go.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 04-12-2013, 04:02 PM   #3
I was planning to wipe the area down with acetone prior to the Dicor as I have read from other posts. Any other thoughts or suggestions to this or my original question?
Old 04-13-2013, 06:51 PM   #4
jeeplj8's Avatar
Check the dicor instructions, they may advise against acetone. I think rubbing alcohol is sufficient.
Old 06-11-2013, 11:22 PM   #5
coryhynes's Avatar
I am in Ontario. Where would i buy the Dicor sealant?
coryhynes is offline   Reply With Quote
Old 06-12-2013, 09:05 AM   #6
jeeplj8's Avatar
Dicor Self-Leveling Lap Sealant - Product - Camping World
if you search around there are other places that often sell it cheaper. Virtually any camper dealer will have this in stock.
