Old 12-07-2018, 10:06 AM   #1
refrigerator access door thingy
The two access doors to the reefer have this quarter turn black rubber things that need a coin or screw driver. A real PITA. Are there replacements for these that have a wingnut kind of handle? Or I am getting way to petty here?
Dan
Flagstaff 625D
Danwilly is offline   Reply With Quote
Old 12-07-2018, 10:39 AM   #2
IMHO you're getting way to petty. My last 4 rigs have them and they've never been a problem. How often do you open these panels? I might look in there once or twice a year just for cleaning and inspection but not any other time.
nayther is offline   Reply With Quote
Old 12-07-2018, 10:43 AM   #3
Mr. Dan's Avatar
I can turn mine with a thumbnail... don't need much else as infrequent as I take off that panel.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 12-07-2018, 11:02 AM   #4
bedubya's Avatar
??? No coins in your pocket?
'17 Toyota Tacoma 4x4
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
Old 12-07-2018, 11:48 AM   #5
Hi,
I use the flat head of a key to turn mine.
FWIW.
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 12-07-2018, 12:56 PM   #6
I carry a stubby straight slot screwdriver in the driver's side pocket of my minivan.
If it's a standard height PUP with a continuous run fridge, you access it a lot. On the road, I had to stop/start the fridge on DC as it would drop below freezing after towing at highway speeds for 4+ hours. Switching modes at arrival/departure is another access. And adjusting the cooling on AC or propane was needed once a day.
A possible fix is to replace Dometic plastic vents with Dometic stamped metal vents. The metal vents have better airflow, but will allow rain into the compartment on occasion. The metal vents I have seen have metal thumb screws and hinges.
The more normal RV fridge in the high wall models has inside controls and automatic features which eliminate almost all the outside accesses. One of the benefits of a high wall. Only disadvantage is reaching the inside controls with the A-frame folded down. I have to unlatch the roof and crawl in with a flashlight to change anything.
just my experiences
Fred W
then 2014 Rockwood A122 A-frame
now 2019 Flagstaff T21TBHW A-frame
pgandw is online now   Reply With Quote
Old 12-07-2018, 02:09 PM   #7
derek6669's Avatar
definately too picky. I can undo mine by hand without tools, but a coin will also work
derek6669 is offline   Reply With Quote
Old 12-07-2018, 03:08 PM   #8
ben31's Avatar
I think I get in mine twice a year. A coin or large blade screwdriver works fine. Is there a reason you get into yours more often?
You could glue a nut onto the backside of the plastic on the RV side and then use a wing bolt to attach the cover. However, to me it would be work to fix something, which isn't really a problem. They do make nylon nuts and wing bolts, too.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 02-03-2019, 08:24 PM   #9
Mine has a plastic vent cover on the bottom with built I bug screens,but the top vent is a metal one,with no bug,wasp guards. How do you all keep wasps out of the top vent.
Ben
benfox49 is offline   Reply With Quote
Old 02-03-2019, 09:48 PM   #10
Come on Forum members. Someone is asking for help. If you cant help or dont want to help, move along. It's pretty rude to call another forum member petty or picky just for asking a question.
There is no value in questioning their desire to do something or the importance of that activity.
Skip12 is offline   Reply With Quote
door, refrigerator
