Old 09-08-2014, 03:13 PM   #1
Refrigerator question
I'm a new be to pop up's. If my trailer is plugged into a outlet will it use any propane or just run on a/c.
fastdog is offline   Reply With Quote
Old 09-08-2014, 03:51 PM   #2
should just be a/c. but just make sure propane tanks are closed. unless you are using the grille or furnace. btw what model pup do you have that way if someone has that model they might be able to help more. mine is a hw276 3way fridge so mine is automatic.
kinma13 is offline   Reply With Quote
Old 09-08-2014, 05:13 PM   #3
Model is 2280. Do you know if there are controls for the fridge. I can't see any.
Old 09-09-2014, 07:18 AM   #4
vinmaker's Avatar
Not sure about your model.
Mine had controls on the front for selecting. It also has an auto feature where the default will be AC, then propane, then DC. I would think you should at least have a manual switch.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-09-2014, 07:32 AM   #5
f5moab's Avatar
Why? I open my valves when I arrive at the campground. If I'm running the fridge on propane, I ignite the propane system, if not, I still open the valves for heat if it will be needed later in the night.
f5moab is offline   Reply With Quote
Old 09-09-2014, 01:48 PM   #6
F5moab my fridge when set to auto will try propane first. Then AC not sure why it does that.
Old 09-09-2014, 06:58 PM   #7
f5moab's Avatar
Interesting. Mine is all manual, requiring me to switch to whatever mode I want.
Old 10-28-2014, 11:21 PM   #8
marsh's Avatar
Our HW277 goes ac then propane then dc when in auto.
marsh is offline   Reply With Quote
Old 10-29-2014, 06:25 AM   #9
My Flagstaff 227 popup is automatic to electric so I have to manually choose propane by lighting the pilot. I found out from my neighbor that while the fridge is on electric it does not get as cold as when on propane. My last trip I actually had a little ice in my sodas with it on propane.
My controls are in the inside panel on the outside of the trailer, it has 1 thru 9 marked with 9 the coldest
Vicfut is offline   Reply With Quote
Old 11-01-2014, 07:11 PM   #10
marsh's Avatar
I had a friend who is a veteran RV'er tell me that he runs his refridge on dc while traveling then cools it with propane before going to ac. He says propane cools much faster.
fridge, refrigerator
