Originally Posted by OLDNAVY
No. Those are LEDs, which I want. The bulb I removed is a regular tungsten bulb
So, the base is right, the LED is what you want.. did you buy them yet?
Go with a USA seller with the highest seller rating on the Ebay link I provided. I bought 20 qty for my last RV. Two failed that the seller replaced for free.
The 42 LED's are slightly dimmer than the halogens. Warm white 2700K is close to the color temp (look) you have now. If you want it brighter in the living space go with warm white 68 led.
Like these.
The wife needed
these bulbs to apply the morning war paint in the bathroom. (6000k bright (white/blue) light)
Edit: If the bulbs do not work when you plug them in, remove and turn them over to reverse polarity. My 2 bad bulbs started blinking, replaced for free.
