Old 02-26-2013, 10:12 PM   #1
Reverse lights
I have a 2008 flagstaff 228. Does anyone know if there is wiring for reverse lights installed into the 7 pin connector? I'd like to put a few backup lights on for the odd late night arrivals. I don't want a flashlight or something temporary. I like permanent hard wired.
am-radio is offline   Reply With Quote
Old 02-26-2013, 10:13 PM   #2
TURBS's Avatar
Not likely if the flagstaff didn't come oe with them.
Tv may not even be wired for them.
Turbs
Old 02-26-2013, 10:36 PM   #3
Jeep4Two's Avatar
The 7 pin Bargman plug has no reverse/backup light provision. Sorry.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 02-26-2013, 11:00 PM   #4
The 7 pin connector usually has a center pin that's used for an auxiliary circuit that can probably be used for backup lights. see link
http://http://www.etrailer.com/faq-wiring.aspx
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 02-26-2013, 11:21 PM   #5
aka Windjammer2012
Crankshaft's Avatar
My previous trailer was a 2000 Arctic Fox 29V and Nothwoods Mfg. saw fit to have backup lights (integrated within the tail lights). The factory 7 pin on my tv was set up for backup lights and I'm sure other manufacturers are the same. It's what happens from the tv back through the trailer that is in question. There are seven wires within the harness that plugs into the tv and I would suspect that harness is complete all the way back to the current lights in the trailer but the wire for the backup light is not used.
I bought the Windjammer too late in the year to do any investigation of the wiring but its on my to-do list as soon as the weather warms up a bit. I WILL be doing this mod as I see the neccessity fo having backup lights to illuminate as you spoke of but in additionally for others to see your intentions of backing up.
Wayne & Vonnie
Layla (American Eskimo dog)
2012 Windjammer 3008W
2004 GMC 2500 HD CC Longbed
Crankshaft is offline   Reply With Quote
Old 02-27-2013, 10:02 AM   #6
I guess it's simple enough to run a wire to the back, but my 7 pin looks "sealed". It would probably easier to get a new one and rewire it. I guess I should follow the wires out and see if I have 6 or 7 wires. My TV has reverse lights and I'm running a tekonsha P3 brake controller.
Old 02-27-2013, 10:25 AM   #7
Dave_Monica's Avatar
You'd also have to change the rear light fixtures or add separate back-up fixtures which would be a better option.
Dave
Old 02-27-2013, 04:45 PM   #8
Just looked and I only have 6 wires coming out of the 7 pin connector. So... I might just have to wire them to a toggle switch, and turn them on when I get to the campground and start backing up. At home, my driveway is well lit up, so not needed.
Old 02-27-2013, 05:01 PM   #9
Missing Link
cyclepuck's Avatar
Your tv will have a reverse wire in it. Just need to add it to the taller side.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 03-03-2013, 09:25 AM   #10
An easier option might be to buy a pair if cheap led lights from Walmart, mount to the rear bumper and run a wire to a toggle switch to the battery. Put in an inline fuse and you will be all set.
whitmw is offline   Reply With Quote
