Old 08-01-2011, 03:35 PM   #1
Rockwood 12V Problem
Hello
Just took my new Rockwood 242XR popup trailer out for the second time this year and everything worked great while hooked up to shore power. When I got home I was cleaning out the trailer and noticed that none of the lights or the vent fan was working when not connected to shore power. I checked the battery and the 25 amp fuse located near the battery and everything was fine. Any thoughts on what is causing this problem.
Metallichief is offline   Reply With Quote
Old 08-01-2011, 03:41 PM   #2
Boyd's Avatar
Check all of the 12 volt lines for good, clean connections.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 08-01-2011, 04:11 PM   #3
Triguy's Avatar
What did you check on your battery?
My guesses would be either the battery is dead (check voltage with a voltmeter. Its dead if below 10.5V) or a bad connection somewhere (clean the battery terminals and check the battery cables and connections. Tighten the connections as needed).
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-01-2011, 05:01 PM   #4
caper's Avatar
Problem with interior lights and fan.
Is there a safety switch inside the trailer. On our pup if the sink was not put in the up position you would not have any power inside the trailer
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
12 Volt
