Old 05-21-2014, 08:20 PM   #1
rockwood 1940ltd awning legs
Looking for a leg replacement assembly for a trim line awning. Wind caught mine last time out and broke the ground pole off of the assembly. Does anyone know where I can fine this?
jlcollins96 is offline   Reply With Quote
Old 05-24-2014, 07:16 AM   #2
Forget it. Dealer wanted to charge us $150 per side. Went to a hardware store, bought a roof shovel that had extended poles made aluminum and replaced them on my own. Better than the factory assembly now.
islandR is offline   Reply With Quote
Old 05-24-2014, 09:07 AM   #3
Thanks for the idea, would you be able to post a picture. This also broke the pole out of the assembly
Old 05-24-2014, 05:37 PM   #4
HONDAMAN174's Avatar
I used a fix by getting a 1/2 to 3/4 copper fitting from lowes and screwing it to the top of the pole. Then drilling out old rivet and put screw thru it- cost about 7 bucks
Just glad to get away
Old 05-24-2014, 07:23 PM   #5
I had that thought but was going to use square tubing that's a cheaper route for sure
1940ltd, rockwood
