Old 08-10-2013, 03:21 PM   #1
Rockwood hw277 power winch
Hi
Just bought a high wall a couple weeks ago. I am concerned about the power winch always having power. Is there a simple way of a lock out or is this something I shouldn't worry about. Thanks
Tommy5351 is offline   Reply With Quote
Old 08-10-2013, 09:30 PM   #2
GalsofEscape's Avatar
I have never really gave it any thought. What concerns you about it?
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 08-11-2013, 07:57 AM   #3
wayne in florida's Avatar
Had the same concern so I put a Key switch in to lock out power to wench when not in use and in storage. I got a lawnmower solenoid (The solenoid is used to handle the load) with three posts and a simple waterproof key switch for the install. “FIRST disconnect the battery” I first mounted the key switch next to the OEM up/down switch and then the solenoid located down below under wench cover noting the mounting hardware is the ground connection so clean all paint off the surface and a shot of dialectic grease between the mount and surface mounting it to. To wire…..I cut the red positive cable to the wench and installed the heavy duty eyelets on each end and attached those ends to the 2 BIG posts of the solenoid. Then using some 14 gage stranded wire I put a jumper from the small post of the solenoid to one side of the key switch and another from the Positive post of the battery to the open post on the switch. I did add a 10amp fuse link in this jumper. Hook up your battery undo roof latches and try the up/down switch and if the wench does not operate turn the switch and try again to lift and it should lift. The switch I got works as when in the on position the key will not come out of the lock and that is what I wanted. Last thing; label the ON/OFF position of the switch. Hope this helps.
2006 Dodge Ram 2500 5.9 CTD
2012 Flagstaff MAC BR28TSC
2012 Days camped 23
2013 days camped 16
wayne in florida is offline   Reply With Quote
Old 08-11-2013, 09:00 AM   #4
What I am concerned about is someone operating switch while top is latched and doing damage. Also, just more secure.
This switch is what I'd like to do. Thanks for the info.
Tom
Old 08-11-2013, 09:35 AM   #5
FYI…….Forgot My brother did change the Solenoid out with this one as the lawn mower one was rated to low to handle the amp draw when lifting. He found this out when I let him use the trailor last year.
Memory is not what it was…..:con fused:
http://www.delcity.net/store/Solenoid-Switch-!-SPST-12V-750:100A-Grounded-Intermittent/p_743399
2012 Days camped 23
2013 days camped 16
Old 08-11-2013, 09:40 AM   #6
power, rockwood
