Originally Posted by seeverest
Thank you for your input. I will try this out sounds similar to what I have going on I have added a foam mattress topper also so maybe that is my issue. Thank you.
A good ratchet strap will exert a lot of force on the roof, so just be a bit patient as you compress things. The foam and the bed covers and the primary mattress will all compress somewhat if you give them about 30 seconds to a minute.
The good news is that when I release the roof clamps, the compressed items do not rebound a lot. The roof doesn't spring up hard as if it was under a lot of pressure. The roof only springs up about 1/2 inch to 1 inch. Most of the time, I don't need to pull down on the roof to flip the roof clamps off the brackets.
So I don't think it harms the camper roof to do this.
Also, the roof clamps are attached with "T-nuts" and small bolts, so there is little risk of them tearing out. The sides of the camper roof are 5/8" or 3/4" particle board sandwiched in the outer gell-coated fiberglass and the inner plastic liner. Pretty sturdy.
I attached my D-rings with #12 x 3/4" stainless screws. Before inserting the screws, I used Gorilla Glue (adheres to wood and metal), in the screw hole and on the threads. So the screws are actually bonded to the roof material. Since all planned loads are "sideways" rather than pulling "out" on the screws, they will hold a lot if you use the Gorilla Glue technique.
A better option would be "T-nuts" and bolts, but there's a LOT of hardware in that immediate area....the roof posts and bracketry are all there, so I didn't want to risk damaging such an important structural item. You could always locate the D-ring to the rear of the roof post. That would place it under the bag awning on the curb side, and it would reduce your leverage ever so slightly, but I'm sure that would work, too.
In my case, we camp in windy areas a lot. Our bag awning flips about and slams the roof when it's still in the bag. So I got industrial velcro and applied it to the roof side and the back of the awning bag to prevent this. The velcro is SO strong that I decided not to mess with it by burying the D-ring under the awning.
