Old 02-25-2014, 09:16 AM   #21
bradnailer's Avatar
Here's the one I put in our pop up. Obviously you use a little space on the sides but I felt like I actually gained space by making the storage more accessible.
2016 Ford F150 Platinum
2013 Coachmen Freedom Express 233RBS
Prior: Jayco Pop Up, Shasta Bunkhouse, Rockwood 2560G Pop Up
bradnailer is offline   Reply With Quote
Old 02-25-2014, 10:38 AM   #22
That looks pretty straight forward.....
Trevor43 is offline   Reply With Quote
Old 02-25-2014, 05:57 PM   #23
I love the idea. Did you use drawer slides on the sides, or just let it slide on the bottom?
cousin_eddie is offline   Reply With Quote
Old 02-25-2014, 06:01 PM   #24
exploreco's Avatar
I like that idea. Good use of space. We just have big stuff stored there now but have to open the seat to get to all of that stuff.
2014 Rockwood Premier 2514G
2010 Ford F150 Lariat
Nights Camped in 2018-2
2017-29, 2016-33, 2015-22, 2014-22, 2013-20
exploreco is offline   Reply With Quote
Old 05-01-2014, 05:52 PM   #25
Going to go pick the unit up tomorrow. So excited!!
Old 05-01-2014, 09:04 PM   #26
exploreco's Avatar
Post some pictures of it when you get it. Hope you have a camping trip planned soon
Old 05-02-2014, 10:26 PM   #27
More pictures tomorrow when it's light out. Quick shot leaving the dealership!
Name:	ImageUploadedByForest River Forums1399087447.247528.jpg
Old 05-26-2014, 04:37 PM   #28
We bought a 90 degree hose adapter for the drain, that really helps with the table on the front. It was only 4 bucks on Amazon, worth every penny. Everything else worked good first time out. Few water leaks from loose fittings, but that was minimal and an easy fix.
Old 05-27-2014, 07:14 AM   #29
exploreco's Avatar
Where were did you find water leaks at? I hadn't noticed any but we got some towels out of that little compartment by the bed where the outside shower connections are and there were a couple of that were wet. The fittings seemed dry and I have not used the show except to dewinterize and sanitize the system. I didn't find may issues with mine either.
Old 05-28-2014, 09:46 PM   #30
A couple of the white turn on fittings were loose. Tightened them up good by hand and everything is dry. Don't tighten them with a wrench, they will crack. Other than that everything was water tight. Don't forget to check the fittings in the cabinets under the sink.
2514g, rockwood, upgrade
