Originally Posted by goody59
2010 Forest River Flagstaff Mac 205 popup. My roof does not go up enough to fit the door in easily, I have to push roof up by hand to get top of door under where it should be. I feel roof needs to be raised about another inch. Is there a way of adjusting roof height to equalise the height of the four posts? I have an electric winch which stops at a set height. My winch needs to raise the roof just a bit higher.
I have a 2009 Forest River Rockwood 1940LTD Pup with a winch, Model P550000, and from looking at my manual it states that if the camper roof does not raise to the designated height allowed, there is an adjustment that can be made via the "upper limit switch", on the winch. Looks to be an easy fix, but if it's still under warranty, best to have it serviced.
I would also suggest checking the tautness ( via the roof cord indicator ) of the canvas when the roof is fully erect and then determine if it is the cable, or possibly if this is a new pup for you, you might be just having a problem with "seating" your door in the groove atop the bottom. Just a suggestion.
Another suggestion, contact FR. They have great support service. Good luck, sounds as though it is something minute.
