So I'm guessing like most things I've probably caused this problem myself. Bringing the roof down felt a little stiff to me so without doing much research popped the cover off of this added a bit of oil probably WD-40. But I was good to go until a couple of weeks later using it again it almost felt like it was completely seizing up.
Doing some research I'm thinking that there should be zero oil applied in this should be perfectly clean for proper operation. ??
Not a hundred percent sure but trying to figure out what I can do to get this thing back in order. It's not slipping or letting the roof slide down on its own and continues to be "overly tight" when trying to bring it down.
Thoughts? Don't really want to tear the entire thing apart as we're leaving in a couple days for a week-long trip.
