Old 08-13-2016, 07:45 PM   #11
f5moab's Avatar
Originally Posted by steamboatscott View Post
Hey f5moab, if you see this, can you PM me directly? I've not received much insight to my question of long term use on bumpy roads. Hoping you have more perspective from there in Moab.
PM sent...there are some things to watch out for on Moab area trails.
I mention the broken spring...
This, I believe, is the trail that did in the spring...
Or, it might have been this one...
Also why the Goodyear Marathons failed too often, and the battery fluid bounced out.
But I can't complain; it was fun and that is why I purchased a popup; never saw any 5th wheels or Berkshires where I used to camp
f5moab is offline   Reply With Quote
Old 08-13-2016, 07:52 PM   #12
Originally Posted by Sistahazel View Post
Personally, I'd stay away from top mounted racks. Especially if you have to penetrate the roof for hardware mounting. Spend that money for a professional fabricator to weld a good solid bumper w/2" reciever to your rig to carry your bike rack. I did just that.
see attached
I detest trailer hitch racks. Bikes are subject to the worst of dirt and debris.
johnbryanpeters is online now   Reply With Quote
Old 08-15-2016, 06:50 AM   #13
I would be a little edgy having the bikes bouncing directly onto the pup roof over rough roads as you describe. It seems to me that would be asking for trouble. If the pro-rack (we use that one, and IMHO the tie down procedure is not too bad) is not for you, you might investigate a custom support system attached to the trailer frame that a rack over the roof could sit on. I saw one on these forums recently for a canoe rack where the over-the-roof section slid into the support uprights and pinned on thereby transferring all the weight directly down to the frame. I did experiment with a rear mounted bike rack, but that adversely affected the weight distribution (Doh!). And it will bounce more as you observed. I'd expect whatever you decide upon will need strap/tie-down to negate the sway you will get.
Cheers.
2016 Roo 21SS, 2016 F150
2015 Rockwood 2514G (pup), 2015 Fd Expl,
2003 Coleman Utah (pup), 2007 Fd Expl
Underthedog is offline   Reply With Quote
Old 08-16-2016, 10:50 AM   #14
2gwright's Avatar
I use a modified Prorack with modified, heavier vertical tubes. This holds
my bikes very well. While I do not take my HW296 down anything worse
than dirt roads, some would consider Georgia Highways as "Unpaved".
They roll front to back but do not bounce.
ID:	117439   Click image for larger version
2015 HW296
2gwright is offline   Reply With Quote
bike, bike rack, mount, roo, roof
