Old 05-21-2015, 06:40 AM   #11
Stormrider151's Avatar
I'm not familiar with your model but when I was a service tech we adjusted cables on Coleman's all the time. Over time cables will stretch. There was a small box under the trailer called a wiffle tree. This is where all four cables met and where the adjustments were made. I don't know if this helps but the first place you would notice this is at the door. Good luck.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-21-2015, 07:07 AM   #12
vinmaker's Avatar
I had the same problem with my HW256. There was a noticeable sag of the roof edge from front to back. It was just something I learned to live with. I doubt there is a fix.
I do not understand how this problem can develop as pop ups tend to spend most of their time closed up and the roof edge is resting on the side wall. I get it if the pop up was up all season and the weight to the A/C unit was pushing down. Then the 12'+ span between the corners could enable sag.
I hope my 16' box roof does not develop this as well but I suspect it will.
I am planning on adding roof braces crosswise to support the roof better to stop the center from sagging. I wonder if I could run some plate metal along the inside as well to give support to the wood. My understanding is that the sidewalls are basically just plywood.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-21-2015, 09:18 AM   #13
What happens if you raise the top set ur door and put the bracing on the cross corners then lower the top? I think that might hurt the door but not sure.
kinma13 is offline   Reply With Quote
Old 06-02-2015, 01:00 PM   #14
Corey Straker's Avatar
The roof on my 2014 HW296 is sagged in the middle over 4 inches. You can see the crazy amounts of water that accumulates. Dealer told me it's normal.
My door does the exact same thing too.
Corey Straker is offline   Reply With Quote
Old 06-03-2015, 07:52 PM   #15
vinmaker's Avatar
Corey,
I will be installing roof braces this year so that does not happen to my unit. I do not want 4" of sag. I do not care if it is normal. You are just asking for problems when water is allowed to pool on the roof.
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-04-2015, 07:18 AM   #16
Originally Posted by vinmaker View Post
Corey,
Vin.
Agreed!! How do you install roof braces? I've been thinking about it but a little too scared to dig into the camper any more than I already have.
Old 06-04-2015, 08:00 PM   #17
vinmaker's Avatar
I plan on using 2" aluminum fence post to span the width of the roof and simple L brackets to hold it flush. There is a good post on it someplace. I will try to find it.
It is very easy to do. Hardest part is mental angush in drilling the bolt hole in the side board of the roof.
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-06-2015, 08:28 AM   #18
macshane's Avatar
I'd like to know how to, also. Thanks
macshane is offline   Reply With Quote
Old 06-06-2015, 01:52 PM   #19
vinmaker's Avatar
Here is the Wiki on it.
How to Install Popup Camper Air Conditioner Roof Supports
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-06-2015, 01:55 PM   #20
vinmaker's Avatar
Also see this thread.
Our 2005 Rockwood High Wall Project, lots of photos!
The discussion on the roof brace begins on Page 5 I think.
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
roo, roof
