Old 08-12-2013, 08:45 AM   #1
Zambolie's Avatar
Roof Shifts Forward On a Level Camper
Making sure the camper is leveled and the stabilizer jacks are down; after I raise da roof (literally ) it seems to shift door side. It is a small shift; but it means that the door does not set in place and often the top pops out of the winged braces leaving a gap at the top.
Our camper (MAC 228D) has an AC unit on top that was installed by the dealer
We have spent the summer like this and have made it work ok for us; but I wondered if anyone else has had this issue and how they have fixed it. I have thought about attaching ratcheting tie downs from the roof to the ground behind the camper.
Thanks in advance!
2015 MicroLite 21FBRS
2009 Ford Sport Trac 4.6L
If you're ever lost... set up camp and now you're home!
Zambolie is offline   Reply With Quote
Old 08-12-2013, 09:10 AM   #2
w4drr's Avatar
If the awning is rolled out, it will pull the roof slightly to the door side. Since we have a high wall, we have to deploy the awning before raising the roof because of the roof height after it is raised (can't reach the awning bag without the use of at least a 6' stepladder). As for putting the door in, we have found it is easier if the awning legs are on the ground instead of plugged into the sockets on the wall.
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 08-12-2013, 09:58 AM   #3
I had this happen once..........it was caused by over using the stabilizer jacks. They should just touch the ground only........if the lift the camper any, you're over using them. Lifting the trailer with them causes the frame to twist and the box to lose shape.
Trevor43 is offline   Reply With Quote
Old 08-12-2013, 10:06 AM   #4
Zambolie's Avatar
This seems to happen whether we have the awning out or not. The awning situation was my thought too.
As far as the stabilizer jacks I have raised them and reset them after set up a couple times to see if something has shifted in set up. I am always careful not to put any weight on the jacks as I don't want to twist the frame.
Old 08-12-2013, 10:15 AM   #5
w4drr's Avatar
Have you verified your leveling with a good level on the floor of the camper over the axle? And just curious, did the dealer install the AC on the centerline of the roof? Or offset some?
Bob
Bob & Doris
Roanoke, VA
2013 Rockwood HW296
Old 08-12-2013, 10:26 AM   #6
Zambolie's Avatar
Bob
Ya. I use a level on the floor right inside the door. I has the cheap-o's stuck on the outside walls. at first but quickly realized how unreliable they are.
The dealer installed the AC unit offset on the driver's side back quarter. The roof shifting door side seems counter intuitive but that seems to be the only explanation, unless somehow the whole camper is off-kilter.
Old 08-12-2013, 10:42 AM   #7
w4drr's Avatar
Our AC unit was factory installed, and it is the same way, offset to the driver's side. I sometimes wonder if it is done that way to counterbalance the awning. It definitely sounds like something is not quite right in the lifter mechanism, but if you have a work-around to make the door work, I doubt if it would be worth the trouble and/or expense to fix it. If you do figure out the problem, post on here and enlighten us.
Bob
Bob & Doris
Roanoke, VA
2013 Rockwood HW296
Old 08-13-2013, 07:27 AM   #8
Incheon, S. Korea
BigBaron's Avatar
Have you measured the distances from the box to the roof at all four corners?
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 08-14-2013, 02:35 PM   #9
Zambolie's Avatar
I have not, Baron. I think I see where you are going with this and I will measure that this weekend.
If one side is indeed raising higher, is there a way to remedy that myself, or is that a professional repair through the dealer?
Old 08-17-2013, 07:48 AM   #10
Incheon, S. Korea
BigBaron's Avatar
You can do it yourself if you know how to turn a wrench or two.
camper, roo, roof
