Originally Posted by cabranch47
Be careful with that rubber washer (sounds like an "O" ring). It may twist or slip. The original one was probably made of material that will withstand the friction/twisting of the clutch plates. Keep your safety shields on opposite lift post to be safe. Would like to know how that works out for you in the event that I need a repair in the future.
The tubular washer I used as my bush fix failed and I had to replace it with the correct part (as you suspected). I noticed it slipping again after I raised it this weekend when we went camping. Fortunately I did purchase the clutch kit just in case!
CareFree does not sell just the washer, so I had to buy the entire clutch kit. The kit was inexpensive so I have some extra parts should the clutch kit gears fail.
