You could use parachute cord to tie down the awning to tent stakes. But then, you have the obstruction on the ground anyway. An "aftermarket" latching device is an option, but a pain, and it means using bolts if you expect it to hold up.
I have used both methods, and I vastly prefer the following:
1. Vertical poles, staked down. But staked down, the poles can still shake up and down, so I also use...
2. Parachute cord to additional stakes about 2' from the poles at a 45 degree angle. I use orange stakes, and the loop in the parachute cord for the trucker's hitch makes a good place to put a "flag". I've not needed a flag, because I have enough extra cord to make a knot with large, slip-knots that are very visible. This adds tension to the awning, and it reduces flapping in modest winds.
I use a trucker's hitch in the parachute cord, and apply a good strain on the cord. This does a lot to secure the awning in MODEST wind conditions...common in Colorado.
If you have the "ball-and-socket" pole ends common on Dometics, order spare sockets. They are fragile, and you MUST use them on the horizontal poles that tension the awning.
Be sure to use the Velcro ties on the sides of the canvass to join the canvass to the side-tension poles. If these Velcro ties fail, buy some aftermarket canvass tensioners.
Two other points:
Protect your awning bag from the sun. My bag is shredding after three years, and by the end of this summer...the 4th season...I'll have to get a new bag (at a custom canvass shop) or a new awning.
If you frequently camp in windy conditions, you obviously must stow the awning to protect it. But under the right conditions, the bag can swing and bang on the roof. This will shake the camper...HARD. I solved this by using heavy-duty industrial Velcro behind the bag and on the side of the roof. Roughly 12" long by 2" wide. This keeps the bag from swinging in the wind. Keep the Velcro at least 12" from the socket on the side of the roof so that it's not a struggle to make that connection.
Hope this helps.
