Old 08-09-2015, 09:05 PM   #11
Done with this
How far out from the PUP does it go? It looks like about 10 feet. Did you tell them it was a PUP when you ordered it? We had a big Carefree on our old highwall, but it didn't stick out that far...
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 08-10-2015, 06:57 AM   #12
vinmaker's Avatar
It looks about normal to me for the width out. Photos can be deceiving. What is your thought on this? Does it feel a lot longer than your old domestic? Can you visit a local campground with a tape measure and measure a few.
As far as I know, the bad awnings are primarily made for pop ups. You just do not see people in TT's or 5th using a bag awning.
This is so screwy. It is a simple triangle but something seems off.
I wish I could help more. At this stage I would pull it to a large campground and talk to others about it. I also would measure others poles, awnings, etc. Try to get as many measurements of the triangle as possible.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-10-2015, 08:45 AM   #13
Awning
Looks like a great angle if it rains !!
But it would suck. At that height.
kinma13 is offline   Reply With Quote
Old 08-10-2015, 03:44 PM   #14
I found last fall when I was looking to replace a bag awning that they sold leg extensions to use in carport mode.
Frankgp is offline   Reply With Quote
Old 08-10-2015, 08:26 PM   #15
wuffwuff's Avatar
The easiest fix would be to have the material shorter ... that would pull the support arms up and back.
It's Easy to take 'Liberty' for granted, When you have never had it taken from You!
wuffwuff is offline   Reply With Quote
Old 08-11-2015, 06:54 AM   #16
Wolverine 1945's Avatar
This maybe a stupid question but,,,
Do you have to unroll the hole awning ???
Not clear to me what type of awning it is ???
Wolverine 1945 is online now   Reply With Quote
Old 08-15-2015, 06:16 PM   #17
Fishhawk1650's Avatar
Do you still have door clearance from the awning? The Dometic awning we have will be caught by the door if we don't have the legs on the ground. Thanks to this, we have a pin sized hole above the door :-(
2014 HW276
2003 F150 Supercrew
Fishhawk1650 is offline   Reply With Quote
Old 08-15-2015, 08:11 PM   #18
2014 HW276
2003 F150 Supercrew
Would you happen to have a picture of it setup?
Trevor43 is offline   Reply With Quote
Old 08-16-2015, 08:14 AM   #19
Afraid not. This happened when the poles were positioned on the lower support holders and not on the roof.
2014 HW276
2003 F150 Supercrew
Old 08-16-2015, 06:45 PM   #20
2014 HW276
2003 F150 Supercrew
Ahhhhhhh.....I got-cha.
awning
