Old 03-19-2017, 09:01 AM   #1
Strange water seeping?
I seem to have a little water seeping up from the seam at the edge of my shower in my Freedom (2318g). It had some antifreeze in it so I know it must be coming from the pipes below (nothing in the shower itself). Any ideas?
Also, I really never want to use the inside shower or toilet. Anyone know if there's a valve to shut water off to this side of the plumbing?Click image for larger version
ericwrenn is offline   Reply With Quote
Old 03-19-2017, 09:09 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I very much doubt there is an isolation valve in your system you will have to shut your pump off or shut down city water. Why not use the equipment installed? Back to your question you will have to follow the lines and see if you have a fitting weeping pull the shower control and check the connections at the valves.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 03-19-2017, 09:30 AM   #3
I'll give that a shot when I get home.
I'd rather use that space more for storage and I think we'll only really need the outdoor shower.
Old 03-19-2017, 09:31 AM   #4
Oh, and thanks!
Old 03-19-2017, 07:22 PM   #5
Water seepage
Why did you buy rv?? If you are not going to use shower and toilet you could purchase a rv without those items for a lot less $$$, like a 'roo' or popup
CHERV is offline   Reply With Quote
Old 03-19-2017, 07:30 PM   #6
Flybob's Avatar
Could also be coming from P-trap as usually they are filled with antifreeze during winterizing. There have been other reports of lose couplings on drain fittings. I would check this first as this could be a simple fix.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 03-19-2017, 07:48 PM   #7
crunchman12001's Avatar
X2, check the easy things before you start to disassemble stuff. Pour some water in the drain and check the pipes. Run the water and check the supply lines ect.
2017 Salem Villa Estate 395RET- Ordered - Coming soon
2015 F-250 FX4
Old 03-19-2017, 08:42 PM   #8
We have the same popup. Just inside the door is a small access door that will allow you to take a look at the "faucet" connections on the backside of the shower base. It is quite possible that those connections are a bit loose. Thankfully, you can hand tighten them. There could also be a crack in one of the lines, but you should be able to see most of the plumbing from that access door.The p-trap on this model actually sits below the floor and can be seen under the trailer. Best of luck; let us know what you find.
Metadifluoro
Metadifluoro is offline   Reply With Quote
Old 03-19-2017, 08:53 PM   #9
I'll check the easy stuff after work tomorrow--hopefully that'll be it!
Old 03-20-2017, 11:56 AM   #10
We had a loose water connection
We discovered water on the floor of our PUP and traced it back to a loose connection on the water pump. Not the same place as yours, but I wouldn't be surprised if you found a loose connection based upon our experience.
jmichaelo is offline   Reply With Quote
water
