Old 10-22-2014, 07:15 AM   #11
iceblaze580's Avatar
There is a little round reset button on the water heater its self try pressing that it may work
iceblaze580 is offline   Reply With Quote
Old 10-22-2014, 07:28 AM   #12
mud yapster's Avatar
Mud Dobber in the burners??? Also there maybe an on/off switch in furnace compartment. Is it clicking warning to light the burner, if so it may just have air in the lines. So keep running it thru cycles. Are you sure your propane bottle is full and on. Just a few things to check.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-22-2014, 07:29 AM   #13
TURBS's Avatar
Does the blower even turn on?
Turbs
Old 10-22-2014, 07:42 AM   #14
msantos's Avatar
It did not do anything no clicks
msantos is offline   Reply With Quote
Old 10-22-2014, 07:43 AM   #15
msantos's Avatar
Noting at all no blower no clicks
Old 10-22-2014, 07:44 AM   #16
msantos's Avatar
Propane was on used the stove
Old 10-22-2014, 08:01 AM   #17
TURBS's Avatar
Furnace fuse ok? 12v fuse not a breaker.
Turbs
Old 10-22-2014, 08:20 AM   #18
nps_emt's Avatar
Originally Posted by msantos View Post
I guess I will try again when it gets cooler if not I will have to take it in
hmm.. I tested mine when the ambient temp was about 75 - 80.. however, I cheated a little.. I cooled the internal coil in the switch by using a cool blast of air from an upside down compressed air can. It dropped enough for it to kick on.
Did that contribute to it kicking on? I can't be certain, but, it cam on soon after the blast of cool air.
Jeff
South Florida
2011 Toyota Tundra Crewmax
2014 Rockwood Freedom 2318g
Proud Father, Eagle Scout, EMT and Combat Veteran
nps_emt is offline   Reply With Quote
Old 10-22-2014, 08:21 AM   #19
Maybe the thermostat isn't working
Old 10-22-2014, 01:12 PM   #20
You don't happen to have an On/Off switch on the bottom of the thermostat do you?
Frank Mattox
2013 GMC Terrain
2010 Palomino Y-4124 popup
fmattox73 is offline   Reply With Quote
furnace, suburban
