10-11-2014, 10:46 AM
Suburban furnace
I am trying to test out furnace in my new pup does any body know at what temperature it will turn on
10-11-2014, 10:54 AM
Depends on how warm it is where you are.
Just crank it to max and wait a jag.
10-11-2014, 12:03 PM
Smokin' hot answer, Ford Idaho!
10-15-2014, 06:38 AM
You should have a thermostat somewhere in the camper. Just turn it up and the furnace should click on.
I am not sure where your temp adjustment would be if you are not wired for a thermostat. I would have to guess that the adjustment would be on the unit itself.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
10-15-2014, 07:59 AM
Well I know were the thermostat is I turned it on but it never turned on I was thinking it was a bir to warm for it to turn on.
10-21-2014, 09:35 PM
If it was above 90 degrees in Von Ormy Texas, then it won't come on.
Frank Mattox
2013 GMC Terrain
2010 Palomino Y-4124 popup
10-21-2014, 09:47 PM
It was about 68 when I tired to test it
10-21-2014, 10:29 PM
Gas On?
Fuses OK?
Battery Fuse OK?
Battery Charged?
Frank Mattox
2013 GMC Terrain
10-21-2014, 10:32 PM
Yes to all the above
10-21-2014, 10:33 PM
I guess I will try again when it gets cooler if not I will have to take it in
10-22-2014, 07:15 AM
There is a little round reset button on the water heater its self try pressing that it may work
10-22-2014, 07:28 AM
Mud Dobber in the burners??? Also there maybe an on/off switch in furnace compartment. Is it clicking warning to light the burner, if so it may just have air in the lines. So keep running it thru cycles. Are you sure your propane bottle is full and on. Just a few things to check.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
10-22-2014, 07:29 AM
Does the blower even turn on?
Turbs
10-22-2014, 07:42 AM
It did not do anything no clicks
10-22-2014, 07:43 AM
Noting at all no blower no clicks
10-22-2014, 07:44 AM
Propane was on used the stove
10-22-2014, 08:01 AM
Furnace fuse ok? 12v fuse not a breaker.
Turbs
10-22-2014, 08:20 AM
hmm.. I tested mine when the ambient temp was about 75 - 80.. however, I cheated a little.. I cooled the internal coil in the switch by using a cool blast of air from an upside down compressed air can. It dropped enough for it to kick on.
Did that contribute to it kicking on? I can't be certain, but, it cam on soon after the blast of cool air.
Jeff
South Florida
2011 Toyota Tundra Crewmax
2014 Rockwood Freedom 2318g
Proud Father, Eagle Scout, EMT and Combat Veteran
10-22-2014, 08:21 AM
Maybe the thermostat isn't working
10-22-2014, 01:12 PM
You don't happen to have an On/Off switch on the bottom of the thermostat do you?
Frank Mattox
2013 GMC Terrain
