Old 03-09-2015, 10:25 AM   #1
W4NT3D's Avatar
Suburban Furnace in PuP not working
Recently opened up camper to begin preparing for use, when turning thermostat on, nothing happens. I began troubleshooting with making sure gas was on and turned on stove burners to run gas through the lines. I'm also hooked up to house power and everything else seems to operate correctly. I've read other threads and Im beginning to learn what makes the furnace work. Other threads mentioned that the furnace makes noise or the fan engages, but absolutely nothing happens when I raise the thermostat all the way up.
Suggestions?
2015 Rockwood HW296
2014 Silverado 1500 LTZ
W4NT3D is offline   Reply With Quote
Old 03-09-2015, 10:40 AM   #2
Make sure the thermostat is set to Heat. Check fuse in electrical panel.
Old 03-09-2015, 10:40 AM   #3
When you turn the thermostat up the fan in the furnace should come on then you will her the igniter try and light the burner. If the fan is not turning on I would check the breaker on the front of the furnace. If you take the cover off (if it is like the one I had in my PUP) you should see a breaker make sure that is on. I would turn mine off at the breaker just to make sure the furnace would not turn on with the roof down.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-09-2015, 10:53 AM   #4
vinmaker's Avatar
Could it be you did not flip the switch when you enter the pup to provide power?
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-09-2015, 10:56 AM   #5
My thermostat also had on ON/OFF switch on the bottom, is that on?
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 03-09-2015, 11:12 AM   #6
W4NT3D's Avatar
The light switch on the left as you walk in? I think it was off, I'll try that.
2015 Rockwood HW296
Old 03-09-2015, 11:13 AM   #7
W4NT3D's Avatar
My thermostat's on/off is on the temp slide, all the way left has a distinct 'click' to turn off.
2015 Rockwood HW296
Old 03-09-2015, 11:29 AM   #8
vinmaker's Avatar
Yes. That. I think it is a bit of a fail safe.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-09-2015, 11:31 AM   #9
vinmaker's Avatar
btw. I am so freaking jealous. I am anxiously awaiting the warm weather and for the snow to melt away so I too can open it up and start work also.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-09-2015, 07:56 PM   #10
W4NT3D's Avatar
Found the problem
Found the problem with furnace; 1 set of wires had come undone. Opened side access panel, checked 7.5a fuse, and there they were looking right at me. Twisted them together, put a new wire nut and away we go.
Thanks for all the suggestions, i did them all and I'm smarter for it.
ID:	71068   Click image for larger version
2015 Rockwood HW296
furnace, suburban
