Old 07-21-2016, 03:12 PM   #1
BigMac
bmcilravey's Avatar
Surge Brake Pin Pulled: how to put it back in
For some reason while reversing (and pulling forward, then reversing, then forward, the reversing,...ya, I suck at backing up), my surge brake pin pulled out of my Rockwood 2317G. I am not sure where this pin (small black pin) gets plugged back in etc.
Can someone shed some advice on what to do when that pin is pulled and the brakes are locked. I am guessing it should be able to be plugged back in some where on the hitch.
Sent from my Commodore 64
bmcilravey is offline   Reply With Quote
Old 07-21-2016, 03:41 PM   #2
fonzie's Avatar
Look under trailer hitch and put back pin in holder.....
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 07-21-2016, 06:09 PM   #3
BigMac
bmcilravey's Avatar
Thanks Fonzie. They say there are no stupid questions, but that fox was so easy, it apparently was a stupid question.
All fixed.
Thanks for guidance.
Old 07-21-2016, 06:32 PM   #4
Never stupid questions. We all have had to learn and I still learn every trip out.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
DaveandSue is offline   Reply With Quote
Old 07-22-2016, 05:10 PM   #5
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Bmc,,,,,,The question is,,,,why did it come out? If you don't have enough slack in it when you tie it to your stinger, you're asking for trouble.
Grampa Jim is offline   Reply With Quote
Old 07-22-2016, 05:30 PM   #6
BigMac
bmcilravey's Avatar
Good question
Good question. The true answer to keep it short is a bad hitch setup. The dealer that put my new hitch in for new TV had the shank way too low. Like way too low. So whilst backing up ( and forward and back) I was on a slight slope where something was catching. This is the first in 5 years this has happened and oddly I have parked on this spot many times. So it's a part hitch setup issue.
But ..to solve it, I bought a TT (dark side .....goodness .
Old 07-22-2016, 05:56 PM   #7
Moderators' Assistant
bikendan's Avatar
Just to clarify, it's a breakaway switch for the trailer's electric brakes.
Not surge brakes.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-22-2016, 05:58 PM   #8
Brake Away Pin
Forgive me is you have checked this already but when that pin comes out it puts the full voltage of the battery on the brakes and depending on how long it was out you might have damaged the magnets. To be sure just check the brakes before you head out on your next outing. Better safe than sorry.
DocRob is offline   Reply With Quote
Old 07-22-2016, 09:27 PM   #9
BigMac
bmcilravey's Avatar
Tks
Both valuable responses. Thank u.
Was out for about a day. Hopefully no damage.
#ForSale
Old 07-23-2016, 12:02 PM   #10
You shouldn't have any damage to the magnets. Just a run down battery if you weren't plugged in to shore power for a long time.
led
