Old 07-04-2016, 09:23 PM   #1
Sway bar ?
Which sway bar for a Chevy Silverado and HW296? I can't get over 60 without a bad sway.
lakecumberland is offline   Reply With Quote
Old 07-04-2016, 09:53 PM   #2
Ford Idaho's Avatar
Lots of things to do about sway.
P metric tires swapped out for LT tires.
Anti sway bar setup by the dealer?
Read the manual an do it yourself.
Overloaded unit?
Put it on a diet by tossing things you can do without.
Old 07-04-2016, 09:57 PM   #3
Hugeez's Avatar
Make sure you WDH is set up properly. We bought Cooper light truck tires to replace the stock Goodyear p rated tires. Keep our Coopers at 80 psi when hooked to the TT and make sure the TT tires are aired to mfg rating also.
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
3 nights camped so far in 2020
Hugeez is offline   Reply With Quote
Old 07-04-2016, 10:58 PM   #4
Pill Billy's Avatar
Sway bar ?
Is your pop up level when hitched up?
Do you have enough tongue weight or is your back end heavy with items/water?
I towed a HW277 using my Tundra without WDH/sway bars.
Pill Billy is offline   Reply With Quote
Old 07-05-2016, 05:00 AM   #5
Hugeez's Avatar
Sorry should have noticed it was a pop up before i started giving my 2 cents. Probably need more tongue weight.
2018 PUMA 31 BHSS
E2 WDH
USN 86-92
Old 07-05-2016, 03:54 PM   #6
When I took delivery of our A122 A-frame, it porpoised pretty badly, causing the minivan TV to bob its rear end. And this at 25MPH in the dealer's lot.
Dealer recommended Equalizer E2 600/6000 WDH. Now tows wonderfully. Ride of the minivan is close enough to stock that DW is quite content to spell me driving while towing to farther away campgrounds. No sway up to 75MPH on interstates in 20MPH crosswinds (test, normally tow at 65MPH).
Towing my Coleman Westlake PUP/Ford Explorer (no WDH or anti-sway) was miserable and white-knuckle in comparison. Would start swaying at 62MPH.
I highly recommend a combined WDH/anti-sway.
Fred W
2014 Rockwood A122
Old 07-05-2016, 09:12 PM   #7
I'm going with a Curt 1000/10,000 to take care of the problem.
Old 07-05-2016, 09:25 PM   #8
raspivey's Avatar
That 1000 will probably be overkill. I'd go with something closer to 600 - 800 lb range.
Old 07-05-2016, 10:37 PM   #9
HONDAMAN174's Avatar
When I was pulling my HW277, I found that it pulled better with more tongue weight so my generator and cooler were stored inside the door as close to the front as possible. Now that was a single axle- you have two which makes it harder to get more tongue weight. So three questions, are you pulling with water? Do you have a second battery? And are both propane tanks full? Your unit prob weighs 5k totally full so tongue should be 500-660. I don't think that would even strain your truck with squat. I think move items to the front and if you really want to try a sway bar, harbor freight has one for 32 bucks.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 07-06-2016, 08:12 AM   #10
f5moab's Avatar
I tow with with the front end of the trailer slightly down to apply a bit more weight to the hitch, and have never had any sway when pulling. That includes in strong crosswinds that raised the awning assembly to flap up and down.
f5moab is offline   Reply With Quote
Old 07-06-2016, 10:11 AM   #11
13.
Too much.
As mentioned 600 would suit your needs.
13. is offline   Reply With Quote
sway
