Old 07-10-2019, 08:03 PM   #1
Swing galley problem
I bought a used palomino and there is something not right with the swing galley. It is made by liftco. The arms hit the top of the lower cabinet before the upper cabinet is in place. There is 1 rubber bumper under the back corner, is there supposed to be 4, or did previous owner install one for some reason.
ID:	209563   Click image for larger version
ID:	209564   Click image for larger version
Musselmark is offline   Reply With Quote
Old 07-12-2019, 10:06 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answeed. I don't have an anser but I'm sure someone will chime with an answer to your question.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-15-2019, 10:25 AM   #3
Judging by your pics, looks like you lost the 2 legs on the front of the galley. The 2 rear legs appear to be there.
If you had the legs on the front of the galley, it should raise the galley enough to angle the lift where it would clear the wood and not hit it.
Your pics are very confusing since they are rotated sideways. It actually looks like the galley is situated on the floor, not the top of the cabinet. Threw me off until I realized the pics were shown sideways.
Good luck.
2016 Ford F150 XLT, CC, 4WD, 145" WB, 5.0L, 6 speed, 3.73 9.75" Locking Axle, 1890# Payload, SAE J2807 method Actual 10,720# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom, Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet. Trucks and Trailers.
Mike91 is offline   Reply With Quote
Old 07-15-2019, 05:45 PM   #4
I was thinking there should be 4 legs but the underside has no previous screw holes or any sign there was ever any legs on the front. Oh well I will add some and see if it helps. Thanks.
