01-17-2017, 05:24 PM
Thoughts on Roof - Damage?
Hi All,
I posted these pictures on pop up portal as well. Wanted to get your thoughts on what this could be. 2013 NTU Rockwood Premier. One corner of the roof appears to have rippling. The roof isn't soft nor does it feel like it's delaminating. Also a strange crack in front middle portion of the roof but it's not leaking. I saw one other member on another forum with very similar damage on his roof getting a replacement but haven't heard back on possible cause. Almost appears to be some kind of previous stress on the roof. Of course Forest River said I need a new roof but won't give any idea as to why. Thoughts????
2013 Rockwood Premier 2516G
01-18-2017, 05:33 PM
Good luck in getting it fixed. I had the dealer confirm my 2012 was delaminating while still under the five year roof warranty, but could not get forest river to warranty, and finally the dealer; Robert sales, gave up and now never answers my emails.
I at least thought the dealer was better than this.
01-18-2017, 05:57 PM
F5Moab- I saw your roof pictures on one of your posts. Looked like you had some of that raised cracking. Is that delamination? Has it gotten worse? Any ideas what caused?
01-18-2017, 07:57 PM
Hasn't gotten any worse that I can tell since it has been buried under a foot or more of snow for a month or two. I did seal it up with some dicor before winter hit; so hopefully, there is no leakage onto the wood. I'll find out in the spring.
What causes it? I'm thinking it is bad workmanship at the FR assembly line that makes the roofs. Dealer also stated it was delamination and FR "should" cover it.
However, I gave up writing the dealer and receiving no answer. So I figure in the spring, I'll put a coating of a truck liner on it and see how that works. I have read some great recommendations for Grizzly Grip on another forum.
I've given up with both the dealer and FR and if I get another trailer, I'll make sure it is not a FR product. I would say I would stay away from Roberts Sales too; however, they only sell FR so that will be a given.
01-19-2017, 01:24 PM
I had a small slashcaused by a tree branch. I took a knife and created a slit then worked a piece of riffing patch under it and glued the patch to the roof. Next I glued the top of the patch and pressed the roofing down onto the patch. After the roofing glue dried I spread riffing glue on top. Been five years and no leak.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
01-19-2017, 01:25 PM
Fiberglass Roof Wrinkle
Found the a similar condition on my Georgetown fiberglass roof ater I had had it a few months. But mine was a wrinkle or crease. I did not pursue any corrective action. Perhaps I should have but, I put al bead of roof sealant along the wrinkle which has held up fine and I and have had no leakage. The fiberglass seems pretty stiff compared to a rubber roof and, so far, there are no signs of delamination.
01-19-2017, 03:00 PM
Hikerjohn do you have any photos?
01-20-2017, 09:48 AM
I also have the same ripple on my 2318's roof. No cracks yet. I'm keeping a eye on it. Check it in the spring after i take the cover off. I just thought it was a normal occurrence.
2013 Rockwood popup 2318 g. TV 2016 acadia and a 2013 SLE Sierra p/u
01-20-2017, 02:37 PM
Not Yet
I'll take on an send it in.
01-20-2017, 04:03 PM
I had an interior ripple on my 2016 228BHSE. The dealership was able to get FR to agree to replace not only the top but the complete lifting system as well since it was having issues due to bad welding at the junction between the winch cable and the cables going to the top itself. Yes the repair took a few months waiting on FR to send the replacement top but the dealership (Lone Star in Houston) was fantastic in getting the pup back quickly once the items were received.
01-20-2017, 08:49 PM
Donc Glad to hear you are getting a replacement Unfortunately I'm not the original owner. Campfire Joe that's interesting to hear, notice you have a 2013 also. Love to see your pictures if you get a chance
01-21-2017, 09:31 PM
For any cracks or holes, I would use marine epoxy. It dries up rock hard, stays white, doesnt shrink. The roof ripples seems not to be water damage. Looks like something was placed or hit hard. Does it seem like just the skin? Or does it seem the whole roof material is warped?
Dutchmen
01-22-2017, 05:36 AM
Dutchmen
It seems like just the skin. I don't think it's water damage as the ripples are hard to the touch and will move a little but only if I press down hard. I've taken the tent material off and examined the inside of the entire roof and did not find any staining or soft wood. I looked at what seems to be the long crack with a magnifying glass and the fiberglass is still solid. I've sent several pictures to Forest River but other than telling me I need a new roof, they won't tell me why they think so after repeated emails. It very well could be something heavy was placed on top. Camper was garage kept (according to owners) so no telling what was set up there. If it is a defective roof I hope it's like some of the others here and doesn't get any worse.
01-22-2017, 04:46 PM
I purchased my 2016 Rockwood Premier 2516G in August 2015. I recently waxed the roof and noticed similar scares. I thought it was just the material used or some imperfection, I guess not!
Im pretty sure I'm still under warranty so I'll have to get it looked out before it becomes a bigger issue.
01-22-2017, 05:20 PM
I would say you are definitely under warranty if you are the original purchaser. I hope you don't have the same problems F5moab had. Can you post some pictures and please keep us updated as to what dealer/Forest River says.
01-22-2017, 07:01 PM
I just put it away so give me a couple of days and I'll post some pics.
01-22-2017, 08:32 PM
01-22-2017, 09:22 PM
cunddiff, yes i do have a 2013, but it's a 2318g, looks like yours is a 2516g. Can't do any pics right now, it's tucked away for the winter.
01-23-2017, 08:09 AM
I would hope not, but have come to believe a lot has to do with the dealer, and the dealer (Roberts Sales) who I purchased the unit from did not appear to care. (I say did not, since I have given up on the thought of Roberts or FR to do the right thing.)
01-23-2017, 08:29 AM
I'm sure these dealers and Forest River are aware of roof problems or some kind of quality control issue. Just seeing members post with similar roof problems would suggest it. My biggest reason for wanting to know is I'm debating shelling out $800 for a bullet liner spray on the roof and don't want to do it if the entire structure would eventually come apart underneath.
