Old 06-01-2016, 06:16 PM   #21
Thank you tireman9. I'm glad I posted this, I have learned a lot in a day. My plan is to step up next spring. How can you have tpm on a popup camper tires. Or and trailer tires. Is this programmable on the tow vehicle?
Sent from my SM-G920V using Tapatalk
ESDSKeith is offline   Reply With Quote
Old 06-01-2016, 08:59 PM   #22
Commercial Member
Originally Posted by ESDSKeith View Post
Yes. 80 psi. Had to replace one when new, was going flat. Had a plug. Hmnn. Think from when it was being transported, must have been plugged. Dealer couldn't find a 80lb. Match
Now i have 2 different tires . Need you get 3 good tires. Any recommendations?. I'm planning on getting a Roo this winter, but need to be safe rest of summer.
What Load Range (inflation) is shown on your Certification label (tire placard). Did the dealer show you the placard during initial walk through?
IMO if the dealer delivered the RV with the incorrect tires as specified he owes you a new tire.
A plug repair is specifically NOT APPROVED by any tire mfg I know of and is NOT APPROVED by DOT so the RV dealer delivered a potentially unsafe tire and a complaint should be issued to NHTSA against the RV dealer and you should contact the RV company and advise them of the dealers actions. If you had a tire failure and accident the only question would be how many zeros would come after the dollar sign and number as it would be impossible to defend against this practice.
If you bought a new car or truck would you be willing to accept a rebuilt engine in it?
How about having used brake pads installed in a new vehicle.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 06-01-2016, 09:05 PM   #23
Commercial Member
External aftermarket TPMS can be installed on any tire. If you only need on a TT with two tires I may be able to put you in touch with a dealer who will reduce the price for only 2 sensors as normal is 4.
The reading is on a dash mounted, battery operated (rechargeable) monitor.
There are a number of brands but I prefer one with Lifetime warranty.
HERE is blog post on how to select the "Best TPMS' for your situation.
Old 06-01-2016, 10:58 PM   #24
Tire blow out
We had a tire blow out Memorial Day weekend. We bought our camper new last year. We were lucky no damage to the camper. We didn't even realize it blew out until we were backing into our driveway. Not sure how long we drove on only 3 tires. Now we are researching if we should change all tires to another brand. We are not hearing anything good about the Wakefield Super ST tires it came with. Does anyone know about these tires ? We only drove an hour and 40 min on the highway and stayed 60 to 65 MPH. Doesn't seem year old tires should have a side blow out so soon.
rollingroo is offline   Reply With Quote
Old 06-01-2016, 11:24 PM   #25
clr
If you ran on three wheels for any length of time you have also damaged the other tire on the side with the blow out. That tire was caring the total weight of the camper on that side of the unit, and was overloaded. It will only be a short time until the damaged tire also fails, so you might as well go ahead and replace that tire also.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-01-2016, 11:28 PM   #26
Commercial Member
Can you post a few pictures? It would help me understand the tire condition and may provide clue as to why you had a failure.
Before you change all the tires you should ask yourself this question. If the failure was due to a puncture or leaking valve would you consider the failure the fault of the tire?
Have you ever weighed the RV and made an effort to confirm that none of the tires were overloaded? You do realize that multi axle trailers seldome have the load split evenly between axles and also seldom split evenly side to side.
HERE is link with info and worksheet on how to learn the real load on each tire.
More general weight info HERE
Old 06-02-2016, 07:31 AM   #27
We did hit a large pot hole the week before but it didn't appear to do any damage. We thought of checking the weight. But not sure where to do this? Looking at the tires they never really looked like brand new tires .
KB
Old 06-02-2016, 10:53 AM   #28
Commercial Member
Pothole not blowout
NOTE. I may have forum post and tire condition confused. I received pictures in email but no sender name. Also incorrect claim of "blowout" which is an ongoing problem. This is like telling police the man is dead but there is a difference between being shot and having a heart attack.
Terminology and accuracy does make a difference if you are trying to solve a puzzle. Many times all I get is a puzzle box, with many pieces missing and sometimes the description of the puzzle scene "a tall object" doesn't reflect if the puzzle is about a tall tree or tall mountain. There is a picture in one thread I am monitoring with a tire with large baseball size sidewall blister. So maybe not this post but the suspected cause is still impact and this is based on evidence observed in the attached picture
Where to weigh See links in my previous post.
Tire damage
Thanks for the picture. I attached a copy.
Failure. Now we get the rest of the story. When you hit a pothole the body cords are subject to "shock" loading and just as you can snap a 10# fishing line with a 5# fish you can also break the body cord. Higher speed can definitely increase the potential for a shock impact break. Sometimes this does not immediately break through the outer sidewall
It may bend the rim, or may just leave a mark as seen in your picture. In a perfect storm the broken body cord may allow internal air to seep into the tire structure and "inflate" the sidewall with a blister similar to this.
I have also attached a shot "Case #2" from one of my seminars on tire failures with examples of observed conditions.
None of the above are "Blowouts". They aren't even a tire defect. Impact breaks are the result of a combination of variables of Load, Inflation, Speed and the size, depth and even shape of the pothole or trash on the road.
I would consider yourself lucky and get a new tire. Maybe slow down a bit too.
ID:	109862   Click image for larger version
Name:	Impact cause.jpg
Old 06-02-2016, 11:30 AM   #29
Commercial Member
Not a blowout
OK what we see here is a thread spinning out of control because of "A failure to communicate"
I need to VENT
The OP has a Tread Separation which is not a blowout.
Rather than start a new thread, which I understand RollingRoo had a failure that was not discovered till he got home. I asked for pictures and received shots of a tire with Impact damage, from an unnamed source via email. Then there was additional important information about hitting a pothole from Rolling. This is what I believe happens with many people who have tire failure. If the tire doesn't immediately come apart they seem to forget or erase the memory of hitting a pothole or driving under-inflated etc etc.
I am trying to offer help here and on a few other threads but am getting frustrated. Either insufficient information is provided or people insist that they have never hit a pothole in their life. At least RollinRoo told me about the pothole.
I have no idea what the ref about WitchDoc is about. I don't think he has even posted on this thread.
OK I feel a bit better. I'm off for a while to mow the lawn and do stuff I have been putting off too long.
The general discussion and confusion may now continue.
Old 06-02-2016, 11:45 AM   #30
BamaBob's Avatar
Originally Posted by geeman53 View Post
Chinese bombs from the factory. Maxxis m8008 is the cure. I speak from the experience of owning two fthwheels w/ no blowouts while traveling nationwide.
X2. Maxxis or GY Marathon's. Replace all your tires: Bump up one load rating, use metal valve stems, have them spin balanced to 65MPH (the max speed of any trailer tire) and strongly recommend you invest in a TST 507 Tire Pressure Monitoring System
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
tire
