Old 09-07-2015, 08:30 AM   #31
Ok so after dealing with FR on this issue, its left a sour taste in my mouth about how future issues will be handled.
That being said I installed the dexter #10 spacer kit Part k71-707-01 I ordered it from Find it Parts, who then ordered it from Dexter $64 out of my pocket( including 2 day shipping) and it was here in 3 days
Before under the dinette and trailer unloaded( no water no gear)
After the spacer install, again no water no gear
The Door side after( sorry no before)
and Finally the total package with TV
It was under 1 hour to install, the longest part was getting the trailer on jacks/ stands so the tires had 3 inches of clearance below them, as once you add the spacer kit you'll need it to get the tires back on.
I then had to flip my 2 inch drop receiver so now is a 1.5 raise to level everything back out.
Air tools and a good Torque wrench will be your friend on this install, as well as having 4 jack stands, and 2 jacks
swimmarz is offline   Reply With Quote
Old 09-07-2015, 08:54 AM   #32
Witch Doctor's Avatar
That looks a lot better, I have been told by Rockwood that I need and do have 3" clearance. That is standard. I can't see how that can void any warrenty myself...
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-07-2015, 09:32 AM   #33
The clearance on mine is tight as well. What is the travel of the suspension? If the travel exceeds the clearance, it wouldn't pass inspection in some states.
JayL is offline   Reply With Quote
Old 09-07-2015, 10:08 AM   #34
no inspection in Florida, however Dexter says you need 3 inches of "bump clearance" with the stock/no spacer I didn't have an inch.
My fear was rubbing on the fender could damage the fender/ tire when traveling at highway speeds.
With out mounting a Go-pro on the trailer to video the suspension travel I have no idea if it was topped out or not, but i fee safer knowing there is plenty of room now as it can go up 3 inches and not hit anything now that i have the spacer installed
Old 09-07-2015, 12:20 PM   #35
What gets me is that they know they need 3" why they will allow it off the line without it is beyond me. Did you see any rub marks on the bottom of wheel well's?....
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-07-2015, 12:22 PM   #36
How would a State even measure that?
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-08-2015, 11:40 AM   #37
I didnt see/ notice any, and now with this installed I sure home i never do
tire
