Old 04-04-2015, 11:47 AM   #11
GreenImp's Avatar
Send a message via MSN to GreenImp
Originally Posted by OldCoot View Post
I personally would never inflate to less than max cold temperature.
Yes, and you also felt the need to add shocks to a trailer that didn't come with any....just sayin'.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 04-04-2015, 12:10 PM   #12
GreenImp's Avatar
Well, I am obviously fighting a losing battle, but here goes...
Here is what Goodyear has to say about it... (hint...it isn't "inflate to max and call it good")
The Inflation Loading - Goodyear RV
Here is what Michelin has to say about it...(hint...it isn't "inflate to max and call it good")
Tire Inflation Basics | Michelin RV Tires
Here is what Maxxis has to say about it...(hint...it isn't "inflate to max and call it good")
Trailer Tire Care and FAQ | Maxxis USA
And to admit that not everybody agrees...here is what Carlisle has to say about it... (hint...it IS to inflate to max and call it good)
The Carlstar Group
Old 04-04-2015, 12:24 PM   #13
Oakman's Avatar
For trailer tires, Iím in the camp with the ďinflate to the maxĒ folks. Iíve never had any issues with the ST tires that were on the fifth wheels Iíve owned. Iím on my third fifth wheel and Iíve been RVing since 2003.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-04-2015, 12:40 PM   #14
You bet and it sure beats any other way of improving truck/trailer ride that I've seen. Don't know of any vehicle suspension without shocks except rv trailers.
Old 04-04-2015, 12:48 PM   #15
No battle here, I just stated what I do and prefer. Naturally, you are free to do whatever you so desire.
Old 04-04-2015, 12:54 PM   #16
The Carlstar Group
Nowhere from above did I see anything about not inflating to max!
grumpyer is offline   Reply With Quote
Old 04-04-2015, 12:55 PM   #17
Well thank you thank you for all of the feedback! Awesome!
Here's where I think I'm going with this. Following some of the suggestions, I've done some research. My tires are rated at 1,520# at 80 psi. That translates to 19 sq. inches in contact with the road at full load.
Based upon the pop up axle weight plus cargo capacity, the tire rated capacity is approximately 150% of the max unit weight; so to approximately maintain the designed contact area for the tire/ full load combination, I should inflate my tires to 55 psi.
But...recognizing that the "full inflation" point of view also has merit, I intend to maintain pressures in the 60 to 65 psi range. Thanks again-what a great resource you all are!!
kraftengr is offline   Reply With Quote
Old 04-04-2015, 12:58 PM   #18
Don't know about anyone else..but my tt did not come from manufacturer with battery or propane tanks! ......just sayin!
Old 04-04-2015, 01:47 PM   #19
So now I have a question!
If sticker on TT states 50psi max. and Class c tires are being used they too are marked on sidewall at 50 psi
What happens when you upgrade to D range and 65 psi max?
.....same load on TT. Do you run at
50 psi or 65 psi. No I'm not trying to be a smart ass!
Old 04-04-2015, 01:59 PM   #20
Witch Doctor's Avatar
I have changed just as you said and I run them at 65 PSI sidewall CP. By GY chart I can run them at 50 PSI for the load, but I would rather run them at the CP 65 lbs. That is also the max my series 6 rims says I can inflate to. I have no problem with bounce or anything. Tires look like new after 2 years and thousands of miles on them. I buy them so I figure it's my choice. Also it gives me a good cushion for the weight per tire/wheel. Some folks may disagree but they aren't paying for them either. Just my choice..... PS: good question
Coachmen M/H
Concord
2018 / 300 DSC
pressure, tire
