Old 04-03-2015, 08:14 PM   #1
Tire pressure
I just picked up my new (actually used a little) pop up camper. I've skimmed thru the pack of manuals that came with the unit and can't find a word about tire pressure. Any suggestions-guidance?
kraftengr is offline   Reply With Quote
Old 04-03-2015, 08:20 PM   #2
Look on the side of the tire, it should have max pressure. Inflate to that pressure when cold (in morning). Never deflate during the day. Just check every morning and inflate accordingly.
Old 04-03-2015, 08:21 PM   #3
Old 04-03-2015, 08:29 PM   #4
GreenImp's Avatar
Send a message via MSN to GreenImp
This is the easiest and most common answer, but not necessarily the best. All major tire manufacturers have "load inflation tables" that will tell you the correct pressure for any given load the tire will see. You would have to find out what the load on your tires is to determine the best PSI for you (which may very well be the same as the tires "Max PSI"...especially with the tires the factories install as they usually just squeak by load rating wise).
P.S. There may be a white/yellow sticker on your trailer giving factory recommended tire PSI...often at the front driver side.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 04-03-2015, 08:40 PM   #5
I maintain the tire mfgrs are better judges of their products than FR. As you say, with the tires being borderline on load, why take a chance by not going with the max pressure recommended by the tire mfgr?
Old 04-04-2015, 09:29 AM   #6
f5moab's Avatar
I'll agree with OC but primarily due to the fact, most will not weigh their trailers; especially popups so the max air pressure should keep you safer in the long run. Also, not sure about those load inflation pressure charts. I wrote a manufacture once and the reply back was basically, "WHAT."
But I will also add that a purchase of a tire pressure monitoring system can help put a person's mind at ease while towing. Many on the market, but I recommend TST.
f5moab is offline   Reply With Quote
Old 04-04-2015, 09:53 AM   #7
I agree, go by what is on tire & use max. psi.
Can't go by sticker on trailer because maybe tires were changed out, upgraded.
grumpyer is offline   Reply With Quote
Old 04-04-2015, 10:23 AM   #8
I agree with the above posts. On many smaller trailers people will actually install passenger car trailers. That's why it's always best to go by what the manufacturer of the tire suggests. Max inflation will help keep your tire temperatures lower. The number one cause of tire failure is under inflated tires or insufficient tire capacity for the load being carried. Good idea to load your camper and find a scale to see how much is on your axle. Divide that by 2 and you should know what your tires are carrying. Check the load capacity of the tire by looking at the sidewall and compare this. Lastly, your axle weight should never be exceeded even if the installed tires can handle a higher capacity. Refer to the placards on your camper for the GAWR figure. This is your gross axle maximum. A lot of info, but hopefully some important things to consider in keeping your family safe and Off the side of the highway.
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 04-04-2015, 10:56 AM   #9
DaveSchwartz's Avatar
I agree you won't (generally) go wrong inflating to the max cold pressure. The vast majority of failures are due to tire heating because of the excessive flexing of an underinflated tire. Once the carcass exceeds a certain temperature, its only a matter of time. However, you won't get the full life of the tire that way.
A tire is molded with a flat face (in cross section) where the tread is. With no pressure, everybody's seen that the center of the tread collapses inward. As pressure is added, the center will rise until it is starting to arch outward. Now when you put the tire on the vehicle on the road, the weight on the tire will flatten that arch out.
Too much pressure for the load and the 'contact patch' will not flatten out enough, there will be too much load on the center and too little on the shoulders and the result will be too much center wear and reduced life.
Conversely, too little pressure will mean that the center isn't being pushed down enough to flatten out the contact patch, the shoulders will bear more weight relative to the center and you will get premature edge wear (and there will be too much flex and the self-heating of the compound due to that may cause a failure).
At the right pressure for the load (what those inflation charts tell you - Goodyear's is here) the contact patch flattens optimally.
So its a Goldilocks thing but it requires you know the load (weight), the section numbers of your tire and have an inflation chart.
Personally, I don't always know my weight (can also change quite a bit depending on whether I'm alone or not, carrying water or not) so I inflate for (max GVWR - pin weight at max gvwr) / 4. This is especially important for folks like myself who went up a load range in the same size. If you went up a load range and inflate to max for that range, the tires will be like rocks and your camper will not be having a good ride.
But if you have the same load range as originally supplied (on the tire placard) you will be safer at max cold pressure than by getting it wrong on the low side.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 04-04-2015, 11:05 AM   #10
Originally Posted by DaveSchwartz View Post
...Too much pressure for the load and the 'contact patch' will not flatten out enough, there will be too much load on the center and too little on the shoulders and the result will be too much center wear and reduced life...
ST trailer tires very rarely, if ever, wear out in the center (disregarding axle alignment/bend axle/bent spindle/loose brg), they age out due to weather cracking, etc. I personally would never inflate to less than max cold temperature.
pressure, tire
