I have a popup with a cassett toilet. I tried to fill the tank with water so I could flush (never been used before). The directions say to pull out the gray tube and fill with water and a little smell good liquid until the small clear tube is filled. I tried to fill the gray tube and the water will not go anywhere. It just sits in the gray tube. WHen I see how the tube is laid out, its attached at the top to the tank so I dont know how water will flow upward anyway. But apparently its supposed to?
I need directions on how to use it.
I already get that I need to fill the waste cassett tank with a little water and smell good liquid so thats not the problem, its the tank that takes the water to flush.
Please help soon if you can Im camping and would like to use the bathroom Monday is a long ways a way
Packncycle
