Old 04-26-2015, 01:29 PM   #1
flagst228's Avatar
Top fridge vent
Got a question for all.. What did u do to cover the vent on top of the fridge. I installed the vent screens on the bottom vents. Do they make a kit or did u take off the cover and cut a piece for behind it. I cut screens for the hot water vents instead of buying the,I just hope it don't slow the heat from going out. Don't need any bee's to have as pets in there.....thanksClick image for larger version
Name:	ImageUploadedByForest River Forums1430072948.132631.jpg
flagst228 is offline   Reply With Quote
Old 04-26-2015, 01:32 PM   #2
Would do the same as the bottom vent.
Old 04-26-2015, 01:36 PM   #3
flagst228's Avatar
Did the bottom with the camco screens,that turned out real nice but I need to now do the top. Didn't know what everybody does to make it easy
Old 04-26-2015, 01:38 PM   #4
Screen wire works just fine on all of mine, including the ac.
Old 04-26-2015, 02:02 PM   #5
Witch Doctor's Avatar
Originally Posted by flagst228 View Post
Got a question for all.. What did u do to cover the vent on top of the fridge. I installed the vent screens on the bottom vents. Do they make a kit or did u take off the cover and cut a piece for behind it. I cut screens for the hot water vents instead of buying the,I just hope it don't slow the heat from going out. Don't need any bee's to have as pets in there.....thanksAttachment 75297
Just put screen behind it, If your worried about over heating, go to lowes or somewhere and look at there foundation vents that have more sq. in's in the opening and then paint it. It looks like a foundation vent to me. Some even come with screen in them already.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 04-26-2015, 03:11 PM   #6
flagst228's Avatar
Ok I took the vent off very carefull so I didn't bend it and cut a piece of screen for it. Put it back on and can't tell I even touched it. So all vents r now screened. Thanks for the replies and it looks cleaner then using all those camco kits on the outside. Now the bee's will go to someone else's popup not mine!!! LolClick image for larger version
Name:	ImageUploadedByForest River Forums1430079076.032885.jpg
Old 04-26-2015, 03:49 PM   #7
Ok I took the vent off very carefull so I didn't bend it and cut a piece of screen for it. Put it back on and can't tell I even touched it. So all vents r now screened. Thanks for the replies and it looks cleaner then using all those camco kits on the outside. Now the bee's will go to someone else's popup not mine!!! LolAttachment 75303
Well you did a nice job, That shouldn't cut down on your air flow, and it sure will stop those unwanted visitors....
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-26-2015, 04:14 PM   #8
flagst228's Avatar
Thanks.... I dont think it will hurt the air flow in anyway
Old 04-28-2015, 07:46 AM   #9
I used metal screen (fr ok m a hardware store) just cut it to fit then zip tied it to the vent. Well not on my fridge but my water tank vents
kinma13 is offline   Reply With Quote
Old 04-28-2015, 07:53 AM   #10
Flybob's Avatar
If you can find screen with 1/8 square grid it will provide better air flow. Also you can add a small ( 4" to 6") 12V computer style fan controlled by a switch behind the top vent. I used one in my last trailer ( mainly during the day) and it improved cooling significantly.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
fridge, vent
