Old 07-30-2010, 11:00 AM   #1
Travel Door
Hi everyone. I'm new to the forum and need information. My wife and I are the proud new owners of a Flagstaff 228. When the top is down and latched, ready for travel, should I be able to open the travel door? Ours will not open. I spoke with the dealer and was told that the door was not supposed to open unless the top was unlatched and lifted a few inches. Does that sound right?
Thanks for any help.
PopUpGuy is offline   Reply With Quote
Old 07-30-2010, 11:24 AM   #2
I used to have a Rockwood PUP and I could open the door when the top was down and latched. With the weatherstrip it was a tight fit but it would open. I can't think of any reason for it to be made to not open, but then I don't know everything! I guess it could be a safety thing so, if someone were to crawl inside, you can't get caught inside with the top latched and the door locked or stuck.
We'll see if anyone has other thoughts.
Ray
grandpaofthree is offline   Reply With Quote
Old 07-30-2010, 11:49 AM   #3
grhodes50's Avatar
I had an '04 Flaggstaff pop-up and I didn't have a problem openning the door when the top was down.
Newer models like yours may be different, although I don't know why.
Sorry I can't be of more help to you.
Gary & Trish
2018 Nights Camped - 5
Old 07-30-2010, 12:09 PM   #4
I looked at the specs of the FR website, and it says that the main door is accessible in the closed position. See the link below. Unless I have read info for the wrong model, it seems your dealer may be wrong.
Flagstaff Tent Campers Standard Features
Old 07-30-2010, 12:57 PM   #5
Thanks for the speedy replies. I am taking it back to the Forest River dealer for several minor adjustments and repairs and I intend to take a copy of the "Flagstaff Tent Campers Standard Features" with me.
Old 07-30-2010, 07:27 PM   #6
flyrotor's Avatar
The pop-up I had for a few years would allow access to the door only if the front latch (closest) was loose, I also had to use some muscle and lift the roof a bit to get the door open, this is the way it should be because with a pop-up trailer the frame flexes a bit while traveling and without a solid door casing the latch won't always keep the door closed securely, several times the door would latch would pop and the door was loose, only kept closed because the roof clearance would not allow the door to open. I even went as far as installing a locking external latch allowing me to put padlock which made vandal intrusion a bit more difficult.
Don't fret this inconvenience, it can be easily overcome and will prevent having an unwanted yard sale on the interstate.
flyrotor is offline   Reply With Quote
Old 07-30-2010, 08:40 PM   #7
I could unlock & open the door on my '06 Jayco. As grandpaofthree said, it can be quite snug opening it.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 08-02-2010, 06:28 AM   #8
Update
For those that may be interested, I telephoned Forest River and was told that the travel door was supposed to open even when the top was down. However, flyrotor makes a good point. The door is very secure the way it is now. So maybe I will just live with the minor inconvenience of having to raise the top a couple of inches whenever I need to open the door.
Thanks for all the replies.
flagstaff, tent camper
