Old 09-09-2014, 04:57 PM   #1
Turn signals & brake lights
I just brought home a 2006 Forest River model 2280. Its turn signals and brake lights don't work, but the running lights work. The pigtail cable had been patched so I cheked it and it seemed ok. I dont think its a fuse as the running lights work. It has a six pin plug that goes into the pup. Any Ideas before I take it in for repairs.
fastdog is offline   Reply With Quote
Old 09-09-2014, 05:07 PM   #2
TURBS's Avatar
You didn't say but late model trucks have separate trailer fuses then the truck.
It's possible for the marker lights to work and the turn and stop do not as they are separate circuits.
Since the camper is used it's very possible that the bulbs are bad as well.
If the cord has been "patched" I'd be tearing into that to.
TURBS
"SABRE OWNERS UNITED"
Old 09-09-2014, 05:10 PM   #3
Truck is a 2009 Honda Ridgeline. Thanks
Old 09-09-2014, 05:14 PM   #4
TURBS's Avatar
Still possible.
Check your owners manual for trailer fuses.
have you checked for the appropriate power on the vehicle plug end?
TURBS
Old 09-09-2014, 06:57 PM   #5
Thanks everyone for your advice. I have checked everything, no luck so I may as well take it in
Old 09-09-2014, 08:12 PM   #6
HONDAMAN174's Avatar
Check your auxiliary under hood fuse box- just to the right of your master cylinder.
Check fuse 1, 6, 7, 8 & 9
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 09-10-2014, 08:37 AM   #7
Will do Thanks
Old 09-10-2014, 01:55 PM   #8
Thank you Honda Man. I did not know I had 3 fuse boxes. In the small secondary fuse box under the hood there it was, a blown 7.5 amp fuse. Will get some fuses tomorrow. Will keep you informed.
Old 09-12-2014, 01:13 PM   #9
I did replace the 7.5 amp fuse in the truck, and guess what everthing works. You guys are great.
Old 09-12-2014, 01:26 PM   #10
Sounds like a camping trip in your near future. Have fun!
light, brakes
