Old 06-30-2015, 12:56 PM   #21
I was messing around with some L brackets or Flatt hooks, one that would hang from the top roof latch, then another hook on a slip ring to snug up to bottom latch. No holes and use existing solid mounts. I can picture in my head but never completed anything.
'14 Rockwood 2318G
'03 Ford Explorer
gruss01 is offline   Reply With Quote
Old 07-05-2015, 07:18 PM   #22
phillip252's Avatar
61cubby, the pvc pipe was a great idea, works like a dream. Will be adding a u clamp to the frame, and still thinking of adding a pipe clamp to the top latch of the pup, pic soon to come.
phillip252 is offline   Reply With Quote
Old 07-06-2015, 09:37 AM   #23
Using the roof latch to hold the top will work pretty well. I'm trying to figure out where a good spot to mount the whole thing will be...lol. We have a rockwood 2514G and the area up front where the outside cable connect is happens to also have the 30amp electrical hookup, the outside shower, and also access door for the slide tray so we shall see. Also need to find a really good antenna to mount on it. I currently am using an RCA flat antenna but it doesn't do all that well and we are less than 40 miles from most of the stations here in the SE suburbs of ST. Paul, even with the amplifier we get alot of pixelation and signal drop.
61cubby is offline   Reply With Quote
antenna
