Old 06-23-2015, 10:05 PM   #1
Pjbingham3's Avatar
Water filter hw296
Anyone know what the part number is for the water filter that is under the cabinet in rockwood hw296 bought this and it doesn't have the filter
Pjbingham3 is offline   Reply With Quote
Old 06-24-2015, 05:26 PM   #2
GalsofEscape's Avatar
Don't know the part number but I once replaced it and it was pricey. I got it from my Rockwood dealer. I have since removed the internal filter and housing and now just use an external filter.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 06-24-2015, 06:22 PM   #3
Pjbingham3's Avatar
Thanks that's a good idea
Old 06-24-2015, 08:42 PM   #4
vinmaker's Avatar
I agree with Gales. The removal of that inside filter is a common mod as if that container breaks off, you will have a small flood. Your most cost effective method is to purchase the external water filters that connect outside.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-25-2015, 06:43 AM   #5
2gwright's Avatar
I picked up a whole house filter at Home depot for $30 (link) and swapped
out the factory one.
The GE filter has a bypass/shutoff valve so when you need to change the
filter you can just turn it off. When winterizing, I can switch to bypass
and do not need to fill the drained housing with antifreeze. Less to flush
out in the spring as well.
It is taller but it does fit with just enough room to change the filter.
GE Clear Whole House System-GXWH20S - The Home Depot
2gwright is offline   Reply With Quote
Old 06-25-2015, 07:24 AM   #6
Pjbingham3's Avatar
Thanks 2gwright I'll give it a try
Old 06-25-2015, 05:04 PM   #7
I use an inline filter that screws onto the water hose. Cheap (about $20.00)and when it goes bad, just replace with a new one,
2002 Rockwood Freedom 2318G
2004 Ford F 150 5.4 liter
3 Chihuahuas Sammy, Delilah,Gypsy
nineoaks2004 is offline   Reply With Quote
water, water filter
