Old 06-27-2016, 03:57 PM   #11
wmtire's Avatar
Originally Posted by lakecumberland View Post
So it would be hot at first then cool or warm after that? I believe that is the problem.
Yes, but your propane should kick back on, after you use so much hot water and the thermostats call for more heat. You stated it never comes back on.
Anyhow, I would make sure of the valves as per in the link above or here:
http://www.forestriverforums.com/for...st-103381.html
Start eliminating the easy stuff, then go from there.
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 06-27-2016, 04:31 PM   #12
If valves are in winterize you are not drawing any water from the tank.. It is bypassed. You are heating what ever water was left from when you winterized
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 06-27-2016, 08:40 PM   #13
I will open it up and try things this week. I appreciate the help. Will update the findings
lakecumberland is offline   Reply With Quote
Old 06-29-2016, 09:37 AM   #14
All valves where open. I corrected it. Will give it a try this weekend and update after that.
Old 06-29-2016, 09:38 AM   #15
Old 06-29-2016, 09:42 AM   #16
So both hot cold and bypass was open. So hoping this was my problem.
Old 06-29-2016, 09:51 AM   #17
wmtire's Avatar
Crossover/bypass should be closed...while the hot and cold valves are open.
With the bypass open, then it was allowing cold water into the hot water line.(bypassing the water heater)...thus when you were drawing hot water from the heater, you were also drawing cold water via the crossover/bypass.
Old 06-29-2016, 09:56 AM   #18
Pickin' & Campin'
And... likely the reason the water heater never kicked back on. (your original complaint)
It was drawing water through the bypass and the water in the heater remained hot because it never left the tank!
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-29-2016, 09:56 PM   #19
Thanks for the help folks
Old 07-04-2016, 10:34 PM   #20
Had plenty of hot water this weekend. Thanks everyone.
heater, water, water heater
