Old 08-07-2013, 06:30 PM   #1
Water Leak 2011 HW 276
Hello all! I've followed the forums since we bought our HW 276 in the Spring of 2011 and found a lot of helpful information. I have an issue now for which I am unable to find a solution.
I have what appears to be a leak on the underside of the camper. I say it "appears" to be a leak because there are two small metal tubes protruding from the underside of the camper directly below water supply lines (and some sort of connections) that are on the floor in the cabinet next to the stove on the opposite side of the refrigerator. I've not noticed until recently any water coming from that area. Upon inespection I did notice the small metal tubes. I can't tell, however, if the water is leaking on the outside of the metal tube or if it is draining FROM the metal tube.
I'd appreciate any assistance that any of you can provide.
Thanks,
Steve
RedSox2439 is offline   Reply With Quote
Old 08-07-2013, 06:54 PM   #2
Jeep4Two's Avatar
Sounds like the low point drains. Is it possible that its coming from them, maybe they are partially opened or not tightly closed.
On my A126 the handles pull up to open (down to close), but yourself be different, I.e. twist to open close.
Hopefully someone with a similar model can jump in and help.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 08-07-2013, 08:44 PM   #3
daydreaming about camping
jeeplj8's Avatar
I concur with my fellow jeep owner.
Can you snap a picture of the area and we can tell you for sure.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 08-07-2013, 10:47 PM   #4
Thanks for the information. That does make sense. There are handles of some sort in the supply lines above the leak. I will take pictures tomorrow and post them. At this point I don't know if they turn or pull up or push down.
Old 08-08-2013, 01:23 AM   #5
GalsofEscape's Avatar
It does sound like the lowpoint drains. If they are they pull up and down.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 08-08-2013, 11:23 AM   #6
Excellent information Jeep4Two, Jeeplj8 and GalsofEscape! Indeed it appears to be the low point drains. (I had always wondered why the camper didn't have them!) Both handles were not completely down. I pushed them down and the leak stopped.
Thank you all for the fantastic assistance!
Old 08-08-2013, 11:26 AM   #7
Jeep4Two's Avatar
Glad it was something simple.
Jeep4Two
Old 08-08-2013, 11:38 AM   #8
Wonderful, glad that was it. Now you can drain your waterlines. I drain the lines after every trip just cause I do not like to have water sitting there for severals weeks between trips.
leak, water, water leak
