Old 07-19-2014, 07:45 PM   #1
Water Pressure
I have a 2012 High Wall. The water pressure has always been good, until our most recent trip. We have a lot less at the sink, shower and toilet flush. Could this be the water filter?
Judgedcm is offline   Reply With Quote
Old 07-19-2014, 07:47 PM   #2
HONDAMAN174's Avatar
Are you on city water or water pump?
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 07-19-2014, 07:49 PM   #3
City water at campground
Old 07-19-2014, 07:59 PM   #4
Are you using a pressure regulator?
Sometimes hose bibs have them already when you get there and are clogged.
Some people do remove their filter inside their unit and run an external filter for higher water pressure. Problem is on most high walls water filter is directly above your power converter making its servicing a messy ordeal.
Old 07-19-2014, 08:01 PM   #5
I have a pressure regulator, and used it until I had the pressure issue. I thought it might be clogged, so I took it off. Same issue. I have not looked at the filter yet, but wondered if anyone had a problem with clogging at that point.
Old 07-19-2014, 08:10 PM   #6
even if you are using city water hookup some campgrounds have very hard water and it will clog up the filter very fast may need to look at that I took the preasure regulator off of my old camper and broke all the water lines one by on after that so not a good idea to eliminate one
jkklops is offline   Reply With Quote
Old 07-19-2014, 10:04 PM   #7
Just saw several posts about the WaterPur Filters being garbage, including this one from someone that fixed the problem - "Today I completely removed the filter fixture after disconnecting the inlet and outlet hoses. I joined the two hoses with a 1/2" x 6" SCH80 PVC nipple purchased from Ace Hardware, $1.49. No installation issues. I'll connect a filter outside between the water source and the camper."
I think I will go that route.
Old 07-19-2014, 10:39 PM   #8
Good deal. Hope it solves your issue.
Never understood why they put the water filter (which you have to replace) right over the power station. Seems like a larger problem waiting to happen.
Old 07-20-2014, 01:32 AM   #9
SKnight's Avatar
Could have been low pressure at the spigot. I bought a $12 screw on pressure gauge from Home Depot so I can check the incoming pressure as I connect. Under 60psi, I don't bother with the regulator to maximize flow.
Next time this happens turn off the spigot outside, turn on your on board pump and see if the situation improves. If it does, it's the incoming pressure. If not, possibly your filter, or maybe there's something else going on.
pressure, water
