Old 05-03-2014, 07:10 AM   #1
water pump pressure
yesterday while sanitizing the water system the pump worked as it should. Today I turn the pump on and it just constantly runs. It won't pressurize the system. I'm not sure what could have changed. Any ideas?
2008 Rockwood Freedom 2318G
2008 Dodge Caravan 4.0L
- Tow package
- Airlift 1000 air bags
- Curt Class III receiver (13364)
- Tekonsha 90160 Primus IQ Brake Control
dakranii is offline   Reply With Quote
Old 05-03-2014, 07:12 AM   #2
Make sure you have water in the tank and no faucets on. Might tap the water pump, it might have the pressure valve stuck.
Old 05-03-2014, 07:53 AM   #3
TURBS's Avatar
Air in the system possibility.
Most commonly the water heater.
Flip the relief valve up to expel the air.
Turn on the furthest water tap and work your way towards the closest to the pump.
Hot and cold.
Don't forget your outside shower if you have one.
TURBS
Sabre owners united!
Old 05-03-2014, 10:07 AM   #4
gettawaydriver's Avatar
Also check fittings and filter housings for leaks and the city water connection for leaking check valve.
gettawaydriver is offline   Reply With Quote
Old 05-03-2014, 10:56 AM   #5
Hot and cold.
Don't forget your outside shower if you have one.!
do this while the pump is running? Let each valve open as I go or open then shut?
- Tow package
Old 05-03-2014, 01:07 PM   #6
TURBS's Avatar
Yes while pump is running.
Open taps and let run long enough to make sure you have expelled all air then close.
TURBS
Old 05-05-2014, 12:15 PM   #7
Never did get it working. I tried multiple times and quit before frustration ruined the entire trip. We settled for no running water this trip and I'll just have to trouble shoot at home now.
- Tow package
Old 05-05-2014, 12:33 PM   #8
Cyclone
beipers's Avatar
I freely admit I don't have your setup and am not familiar with it at all. However i used to have this problem all the time with my old motorhome because the tank fill and city water connection were one in the same and we used a valve to determine if you wanted to fill the tank our pressurize the system. If I forgot to change the valve back to the city connection after filling the fresh water tank, the pump would run continuously but the water would be sent back to the freak water tank.
Sent from my SCH-R530U using Forest River Forums mobile app
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 05-08-2014, 10:03 PM   #9
Check the washer
Check the washer on the incoming hose. I had the same problem. Removed the old washer (which looked a little cracked, possibly from overtightening) and replaced it with new and - boom, it worked again.
steamboatscott is offline   Reply With Quote
Old 05-10-2014, 02:03 PM   #10
I'm guessing the problem has to be air in the system. It worked fine last Friday morning, I drained the system and refilled at camp Friday night, and it didn't work (ie, pump kept running, no water pressure). I'm going to setup again at home next weekend and see if i can get it working.
- Tow package
pressure, pump, water, water pump
