Old 11-03-2011, 02:31 PM   #1
Water Pump - re: winterization
Hello all, i am in the process of winterizing my rockwood popup. After draining the water i have put 2 gallons of rv anti freeze into the fresh water tank. I have moved the valves to bypass the hot water tank, but when i go to turn on the pump, no water or air is going through the faucet. I hear the pump running, so im just curious if its the simple fact that i don't have enough anti freeze in the tank or something else? I thought i would still hearair even if the fluid levels were not high enough? Help!
joltdawg is offline   Reply With Quote
Old 11-03-2011, 02:36 PM   #2
Remove suction side fitting and place tube for drawing A/F into F/W system,then turn on pump. Then drain F/W tank A/F back into A/F jugs. Youroo!!
youroo is online now   Reply With Quote
Old 11-03-2011, 02:39 PM   #3
Jeep4Two's Avatar
Give this thread a read on how to retro-fit a valve for feeding antifreeze into your system without using the fresh tank:
http://www.forestriverforums.com/for...mco-17570.html
If you try to do it with the fresh tank, you will end up using 8+ gallons of antifreeze - you probably only need 1 or 2 with the valve attached to your pump.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 11-03-2011, 02:45 PM   #4
So pretty much you are both saying i did it the hard way and need to add quite a few more gallons for the pump to pick up the anti freeze?
Old 11-03-2011, 06:18 PM   #5
Hoo Dad's Avatar
If you have a drain for your fresh water tank you can drain/capture the antifreeze and start over using the pump.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 11-03-2011, 06:40 PM   #6
TURBS's Avatar
my camper takes 5 through the pump but I have an outside kitchen and an outside shower.
pouring through the fresh tank is double expensive and double time consuming !
going through the fresh water tank can use up to 12 gallons just to get it to go through pump !
Old 11-04-2011, 09:22 AM   #7
daydreaming about camping
jeeplj8's Avatar
If yours is like mine, the pump pick-up line ot he fresh water tank is about 2 inches from the bottom of the tank, which is probably 2 or more gallons still in the fresh water tank when the pump runs dry.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 11-04-2011, 09:26 AM   #8
You are correct, it looks like the pink is in level with the pickup line but i only put 2 gallons in so i assume i need a little more
Old 11-04-2011, 09:31 AM   #9
(Kim)
Labzy's Avatar
The FR handbook states that 4-6 gallons are needed if using the FW tank, so it makes sense that 2+ will be used in the system and 2 stay in the tank.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 11-04-2011, 11:42 AM   #10
Triguy's Avatar
Kim,
Does your FR manual actually recommend adding AF to the FW tank or are they just saying ..."if you choose to do it this way"?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
