Old 07-14-2016, 09:18 AM   #11
Originally Posted by ilmor View Post
My filter housing failed like this during the winter while full of RV antifreeze. Then again we did get down to 10 below. Better it failed then though.
True they fail,but the OP didnt know how to gain access to the Filter assy, thus NOT "Draining/Knowing" if the canister had "Water/Diluted A/F" which leads to Failure also! Some/Lots of Members don't even know "If/Where" their Water Filters are! Youroo!!
youroo is online now   Reply With Quote
Old 07-17-2016, 09:44 PM   #12
We got a new filter housing
I guess I missed the part when we picked it up about the filter housing retaining all it's water so it must have frozen and cracked. We bought a new one for our next trip and I won't forget to empty/remove it this winter! Cost was $51. I like the idea of bypassing it, since it needs to be serviced with a filter and emptied once a year you woud think the cover plate would have a snap design rather than screws. I may took at a modification for that as well.
Thanks for all your help. Everything works well now and we're ready!
AandS is offline   Reply With Quote
Old 07-17-2016, 10:06 PM   #13
Suggest you bypass it and use an external filter. If for no other reason than peace of mind.
Name:	Filter replacement coupling.jpg
ID:	114457   Click image for larger version
Name:	Filter removed.jpg
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 07-26-2016, 12:03 PM   #14
2016 Plumbing Schematic
I have attached a schematic I drew up for the 2016 Rockwood Pop-up we have.
We have a water heater, sink and outdoor shower. I have not included the capped lines I assume are for a bathroom.
As far as the water problem: Both filters hold water even after the lines are drained, so these need to be emptied or removed for winter storage.
I hope this is helpful to others
Old 07-26-2016, 12:07 PM   #15
Here's the picture
Name:	Camper Plumbing Schematic.jpg
Old 07-28-2016, 02:52 PM   #16
X2 on ditching the house filter and go with the external. And don't forget the pressure reg.
Dodaman is online now   Reply With Quote
Old 07-28-2016, 05:42 PM   #17
f5moab's Avatar
All they installed on the 228 was the small particle filter with a metal (or aluminum) element attached to the pump's inlet.
However, the pump instructions do say to remove the element filter prior to winterizing with anti-freeze. However, the small particle filter with a metal element can remain.
f5moab is offline   Reply With Quote
water
